Question about RCA F36673ET 36" TV
Keep changing channel without any input
My 36 inch RCA model no. television F36648 when you turn it on it keep changing channels and sometimes turning on and off all by itself without any input.
  • RCA Master
  • 5,138 Answers
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Posted on Nov 19, 2009
Rca tv truflat 20f511t
Bring up the menu for the tv with the remote and try to find something to the effect of resetting everything to factory default settings. If this does not rectify the problem, it probably is not worth taking in to get fixed as this can be very expensive and the tv is older anyway.
Dec 28, 2013 | Televison & Video
I have an rca f36648 entertainment series tube tv. it has right white and yellow video input on the back that i attempted to plug my playstation 3 into however when i set it to the video input channel it...
It is compatible. The yellow cable is the video portion of the input and the white is the audio portion of the input. When you do this and switch the video mode or change the channel to number 3, it should work
Jun 08, 2011 | RCA F36648 36" TV
Hi got a RCA 36 model F36648 get sound but no picture can bring up menu, do i need to hook up a dvd player or vcr to it
You probably have the internal speakers turned off. Here's a link to the PDF file of your TV Manual:
http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Page 46 of the manual describes how to switch the audio (TV's speakers) on and off.
Mar 05, 2011 | RCA F36648 36" TV
TV WON'T WORK
its an rca this is a known problem. recently on ghost story cuz owners thought house was haunted. no the tvs ir is so sensitive it will power on and change channels on its own if someone enters the room. friend probably new this was happening. there is a fix but must be authorized repair center.
Jun 03, 2009 | RCA F36650 36" TV
Auto tuner provides different results at different times
Hi there you need a gold star arial or your signal (Azimuth window) is blocked (Trees, Building, arial has moved)
Nov 13, 2008 | RCA F36648 36" TV
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
RCA 36 inch ---channels keep changing
Mine did this and I took the back off of it to remove the button panel on top of the tv. It un- snaps from the inside and pulls straight out. My channel down button was messed up but it lookd fine. It has three prongs on one side of it and two on the other. I clipped the two prong side of the switch and put it back together. Works fine now with remote. Be careful as the set picture tube holds high voltage for a long time when unpluged. Unplug overnight and then work on it.
Jul 21, 2008 | RCA F36674ET 36" TV
RCA-f36648
How are you connecting up your tv? also getting new IF connector should not cost more then 100.00 at the most and thats to much .also what are you using for tuner source?you have to connect to vcr,satellite or cable box using externel jacks,use back av jacks yellow video- red&white audio,then you will be using channel 3 or 4 on tv to change channels thru your vcr,satellite,or cable box which ever one you are using for tuner.If you have it connected right your set should work.let me know if you need any more help with this.ThankYou for using FixYa and Have a Nice Day.
Feb 05, 2008 | RCA F36648 36" TV
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
Changing changes without notice
The easiest thing to check is if the channel up or down buttons are not pushed in too far forcing the switch to make contact all the time,the other possible reason is some of the cleaning solution or water might have gone down to the buttons and creating a short making the switch active all the time.For this reason you will need the help of a servicer to find you the parts and replace them.Let Us know if you need more information.
Oct 30, 2006 | RCA F36648 36" TV
Televison & Video Logo
208 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
