Question about Epson Stylus Pro 4800 InkJet Printer
Epson 4800 Pro is only printing a small portion of
(Using Mac with 10.5.x) Epson 4800 Pro is only printing a small portion of an InDesign file in upper left corner. Checked paper/page size and it is correct. Tried converting it to PDF and printing from Acrobat, same problem.
Have reset printers and deleted/reinstalled drivers. Frustration setting in...
Ideas?
  • 10,421 Answers
Printing from InDesign CS3
even if you have the same document size and paper size the printer will not print exactly to edge to edge... so please select scale to fit and check the percentage of scaling if it is more than 95 then your document should look as big as it is desired
Mar 13, 2009 | Epson Stylus Pro 4800 InkJet Printer
Printer won't print 17''x76'' long Banner on Canvas
What is the page setup in the Indesign Program?  Sounds like is is trying to print to the standard paper size of 8.5 X 11.  See if the program allows you to change the page set up to 12"X66" to match the banner.
Hope this helps...
~enov8
Feb 16, 2009 | Apple Computers & Internet
Canon MP600 not printing on full page - in upper left corner
I went to the Canon website and downloaded the drivers for the printer and it printed out right--on a full page.
Feb 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Size of page printed small
Check your default paper size on both the document program you are using and the printer. You could have it set for 5X7 and that's what it will figure for, even with 8 1/2X11 paper.
Jan 30, 2009 | Canon i850 InkJet Photo Printer
11x17 Landscape will only print 1 page then switches to Portrait
I found an acceptable workaround. If I leave the paper size set to "defined by driver" in the Print dialog box and chose the paper size in the Page Set Up dialog box, that seems to do it. There were numerous complaints on the web about this and it seems to be a major glitch in CS3 with the Leopard OS.
Jan 13, 2009 | Canon imageRUNNER C5180 Color Copier
Epson R1800 prints do not lay out on paper correctly; off center
Hi-
But goal is to have a borderless printout right? when you go to page setup and choose paper sizes when you go to letter size, does it have a slider for letter- borderless? and when you go to file print and and check the print setting/ print layout is fit to page selected?
keep me posted. Thanks!
Jul 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper misfeed
Try to clean the Paper Feed Sensor
Dec 15, 2007 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Photo R1800 Won't Print Colors Right!!!
If you updated your mac then what happens is a generic driver (GIMP/CUPS) got installed. Do the following:
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Nov 09, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
131 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
