posted by shawn85086 on Jan 11, 2008
The Problems that I have with the monitor is that the monitors control buttons act up without me touching them. The monitor switches from vga to dvi, changes its brightness to 100%, opens the menu, and shuts off after 5-10 minutes. (they also dont respond when I push them) If I unplug the monitor and plug it back in it will go back to normal for a few minutes then go through the same thing. What part needs to be fixed on my monitor?
Comment by shawn85086, posted on Jan 15, 2008
I took the monitor apart and saw that the menu controls have there own little circuit board with a cable. I unplugged the cable and no more problems :) I can't use the menu buttons but I never use them anyways.
Best Solution
posted on Jan 11, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The best advice that i can give you, if you had opened a LCD before
then it not a problem to talk you threw the repair but if you have`nt best to take it in for repairs max charge on a job like that 2 to R300
if you in the area of gauteng i can help you out
craig:)
craig:)
Rating Locked! (?) shawn85086 has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for ASUS PW201 LCD Monitor
Email this problem
Email this problem
Can you Help with these Monitors problems?
Repair Service
Find Monitor Repairman Near You:
