Question about Dell Inspiron 2200 Notebook
No brightness to the screen background is dark.
    Brigadier General:
  • 10,406 Answers
Take the laptop into a darkened room.
Does the correct image show, but very dim ?
If so, then the "back-light" in the LCD has failed.
It's about a $20 part, and it will take a qualified technician less than one hour ($60?) to disassemble the laptop, replace the part, reassemble, and then test the laptop.
Posted on Nov 19, 2009
Screen too dark
go into settings and look for personalisation the change your background if that dosent work its probably on night mode or you have it on auto set
Aug 31, 2016 | Acer ICONIA B1-710-83171G00nw 8 GB Tablet...
Dell Inspiron Screen Gets Darker
your screen might need to be replaced. soon you wont be able to see anything. replacing the screen should be an ez fix
Feb 28, 2014 | Computers & Internet
Mottled background
Sounds like you may need a new lamp according to my Samsung DLP manual for a HLR4667W.
"Why do I need to replace the lamp?
The lamp used in a DLP TV has a limited lifespan. For the best screen quality it needs to be
replaced periodically. After replacing the lamp, the screen quality will be bright and clear as new."
Nov 12, 2013 | Samsung HLP4663W 46" Rear Projection HDTV
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Nav background color changes by itself
it dims so u wont get blinded from the lights
Mar 30, 2009 | Dodge Ram Cars & Trucks
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Dell Inspiron 2200 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
