Question about Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV
Power on have the same problem as someone else posted in Jan 07. I turn on the Panasonic plasma screen, and the light turns green as if it is about to turn on, but after a few seconds it shuts back off and a red light flashes instead of the green that is supposed to show when the system turns on.
  • 1 more comment
  • Greg_hw Mar 01, 2008
    my TH-42PHD6UY has the same problem. Have you been able to fix yours by any chance? I would like to hear about your solution.
  • Gina1955 Apr 10, 2008
    plasma works for a while, switches off about after30minutes, red light blinking About 10 mins later can switched on - manually only.,Works for a while, and back to square 1...... Steps considered: chuck it to the wall....
  • keithhenson May 09, 2008
    Hi All,
    Same problem here. Panasonic 42PWD5.
    Now about 5 years old but already had the problem once - about a year ? (frantically searching for the repair invoice!) ago when we were told it was a failed power supply. Cost a packet to fix but all was well until today when suddenly the screen turned off. Turned back on & get a green light for a moment, then high pitched whine the screen blacks & red light flashes in a sequence of 2.
    Any ideas? Has it finally died?
    Have to say that it has been an awesome pice of kit - hence we were prepared to repair it last time.
    Thanks,
    Keith
    Problem Solver:
  • 8 Answers
Depends on how many times it flashes RED.
On the units with fans (usually the HD models) a 6 blink flash code indicates improper fan rotation and the unit will shut down.
These blinks are counted as they go DARK, not as they light up.
Remove the rear panel but do not clean out the dust from the fans until you see which has the improper rotation.
Cleaning may help once you find the baddie, if not they will need to be replaced.
T Wiz
Posted on Mar 25, 2008
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: inability to turn on plasma screen
You have a power supply fault or one of the drive boards that drive the plasma screen is loading down the power supply. This power supply may be part of the entire main board. Good Luck
Posted on Mar 23, 2007
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from www.badcaps.net
Jan 10, 2016 | LG 60PZ550 3D Plasma TV
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
I have a Panasonic th-42pw5 plasma screen
most likely it is the buffer boards and the z sus
Feb 12, 2018 | Panasonic Televison & Video
Green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
Jul 10, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic th-42pz77u 42ed
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
Jan 07, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV screen turns off, green light stays on
As posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Aug 31, 2007 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Inability to turn on plasma screen
Mar 23, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV Logo
419 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
