Question about Stoves Dishwashers
We have a Stoves dishwasher 450DW showing falt E4 overfilled but there is no water to be seen and no explanation how to clear the fault can you help?
I had the same problem and emptied all the water from inside the main compartment of the dishwasher but it still showed the fault. After reading some stuff I took the dishwasher out and removed the side panel. At the very bottom of the machine was a big pool of water.
I think that when it is overfilled or the drain becomes blocked, there is an overflow that dumps some water into the base of the machine triggering a switch and shutting it down.
I cleared all the water out from the base pan and then put it all back together and that has cleared the fault and we are up and running again with clean dishes.
No need for an engineer to come out this time!!!
Posted on Dec 22, 2009
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Error 4
How to start dishwasher 450dw
Apr 21, 2011 | Stoves 23 in. Q60DW Built-in Dishwasher
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
E4 fault code
Hi, when a dishwasher goes into overfill mode it usually means that the bottom tray has water in it that operates a float connected to a microswitch. Open the bottom panel and soak up all water then check to make sure the float is down completely.then restart dishwasher. Why it has overfilled is another problem. It could be a faulty pressure switch,pressure switch hose may have a hole in it, water valve may be faulty. Too much soap or wrong soap can cause too many suds and hence overfill.Also if rinse aid is spilt when filling. Or seals leaking. etc.
Feb 02, 2009 | Dishwashers
E4 shows up when i turn on my dishwasher
E4 is an overfill code caused by water pressure problem.
On the base of the unit - (underneath the kitchen plinth) there are 2 black plastic clip panels - each these of with a blunt knife or screw driver and turn off the appliance at the mains. In there you will see lots of wiring etc. Simply get a dish cloth and mop up any water that is in there, particularly at the back left as that is where the sensor that detects the over flow is. Its simply a rubber valve that is boyent and so lifts when water is present. then once most of the water is removed, turn on.The problem would be solved.
TO PREVENT THIS HAPPENING - when you take off the kitchen plinth you will see 2 small clear pipes in the centre - between the 2 plastic panels. These are cable tied. Simple cut the cable tie and feed the pipes out of the dishwasher - place a bowl under tehre if you whish. This will prevent overfloww water enterin the base. BE WARNED BY DOING THIS THE DISHWASHER WILL NOT HAVE ANY OVERFLOW PROTECTION CAUSING POSSIBLE DAMAGE TO KITCHEN AND APPLIANCE. My advice would be to leave it in place but try to prevent overflow - i.e rinse plates first or try a different brand of wash tablets. If it does happen then the fix is simple and you definately do not have to remove the unit as many people imply.
Jan 20, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Kenwood dishwasher
E4 means overfilled which in practice means there is water in the tray at the bottom of the machine. Lean the machine forwards and the water will drain out and clear the fault code. chances are it will fill up again so if it repeats the leak will need to be found.
Oct 27, 2008 | Kenmore 46123 Stainless Steel Electric...
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Kenwood dishwasher kdw8st2a
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Jan 22, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
Dishwashers Logo
371 people viewed this question
Top Stoves Dishwashers Experts
Owen Barnes
 Russ Hill
Russ Hill
Bill Boyd
Are you a Stoves Dishwasher Expert? Answer questions, earn points and help others
