Question about Cameras
Stuck camera lens
Lens is stuck out.There is no response.have changed batteries.
  • 641 Answers
SOURCE: Lens is stuck out
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 04, 2007
SOURCE: lens cover stuck open
v12mike--you rock! this did indeed fix my stuck lens cover.  to add on to your solution, i had the top half of the cover stuck shut and the bottom half stuck open.  to get the bottom half to the shut position, i covered the lens with a little piece of paper and then used tweezers (VERY gently) to ease out the inner segment (segment 2 i think by your account), and held it in place as i reset segment 1.  this did the trick!
appreciate your help immensely....cheers!
Posted on Oct 11, 2008
t00nz
  • 4738 Answers
SOURCE: kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Samsung Camera won't turn on and the lens is
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 30, 2010
  • 11967 Answers
SOURCE: camera's lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
I have a kodak Z740. The last time I used it the lens got stuck in the mid way part it did not retract full. after which it just turns off. I guess the batteries get overloaded with a stuck motor. can u...
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Jan 25, 2011 | Kodak EasyShare Z740 Digital Camera
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
EasyShare CD82 non-responsive - Lens stuck open
Hi there its a problem of lens guide pin. may its damaged or dislocated. Its a possiblety of company manufacturing default. So repair or replaced that. Its till under werranty. Thanks. bd4ebca.jpg
Apr 02, 2010 | Kodak Easyshare CD82 Digital Camera
Canon A580 lens stuck open with lens error
Put in real Kodak batteries. pull out the lens a bit. same just happened to mine
Jun 27, 2009 | Canon PowerShot A580 Digital Camera
Samsung S730
Try to remove your batteries for a minute and then reattach them again.
Jan 07, 2008 | Samsung Digimax S730 Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Lens stuck out
The lens probably has some dirt or grime stuck in the lens motor. If you can gently twist the lens back and forth, maybe with some air.
I have answered this in another post. Here is the link.
If this helps you, please return and choose FixYa! ThankYa!
Nov 18, 2007 | Canon PowerShot A410 Digital Camera
Camera does not respond and lens stuck
Make sure the batteries are good.
The computer cannot detect the camera unless it is operating correctly.
The camera may be dead, and thus good for selling on a site such as Ebay. Sell it as is, repair, or parts.
take care
Nov 18, 2007 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
