Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Ive locked my spare keys in my safe and cant open it
Can i do anything to open my safe and change my pin number because i cant evan get in to get the keys you get with it incase you do what i have done ?? please help because its got so much stuff i done want want to loose x
  • 576 Answers
Without the code or the keys, chances aren't good unless the lock is a simple wafer lock which could be picked easily. Try calling a local locksmith -- I can't pick locks over the internet and will not teach it for obvious reasons.
Posted on Nov 20, 2009
Dear Expert I have insert my safe key and follow the procedure to open the safe but after many tries, the safe cant be open and the key is stuck in which I cant take it out or open. Thank you
so all keys and locks work by the way of pins falling into the grooves or v?s cut into the key.
Your key is stuck because youhave got the first part of your combination correct and oneor more pins have dropped into the key grooves.
Reset your combination dial by spinning anti-clockwise a number of times.
then very carefully allign it at zero NOTE you must be very gentle and precise when alligning all numbers whilst remembering to go past the number the designated turns EXMPLE 1st No 3 times past anti-clockwise stopping on 4th time
2nd No 2 times past clockwise stopping on 3rd time ect
If you repeat the combnation in full all the pinb will drop turn key whilst jiggling door handle and hopefully it opens if none of rhis works contact the manuacturer with your mode no key no and proof of purchase receipt and details of store where purchased
Apr 30, 2018 | The Computers & Internet
Keys inside 93" tercel ,but i have a slim jim, cant seem to get it open
locked keys inside, keep spare in wallet, i shave them down
or buy a flat key for pocket, (safe for life)
there are only 3 ways
1: lock smith picks lock.
2: you give him key num, and he cuts one with special tool.
3: break window (slim fails)
4: get one at dealer. they look it up and bingo.
5: drill out lock , and buy new lock.
Dec 20, 2013 | 1993 Toyota Tercel
I have a supra touch pad key lock but the code accidently got changed and no one can remember it how do we open it now
Well there are may ways,,, I cant really post them here as this is public and a lot of BAD people use the net too.
I once forgot my combination but I used this basically it will generate every possible combination for you, a 5 digit sequence will take about 20 minutes to go through..
Also I remember once a friend left for vacation. While he was out a clever Thief used battery acid to melt away the plastic coating and then used a chisel and hammer or something abound that thereof to break the rest open.
and as another friend told me, When all else fails a Huge Hammer works.
Please remember these locks are Advanced and you should call a locksmith as it will be wrong of us to tell you how to bypass.
Dec 28, 2012 | Supra 001004 Push Button Lock Box Key Safe
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Feb 24, 2010 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Apr 27, 2009 | Safe International Digital Electronic Safe...
Electronic digital safe richmond
after six years of good service the batters ran out when we were not at home sadly after all this time I cant find the security key to open my safe the number of it is ho 155 how can I get a new key
Apr 07, 2009 | Safe International Digital Electronic Safe...
New Lexsor safe LXo24 Model
Hi there, I had the same problem yesterday but luckily remembered the code and got the safe open. The factory pin is 159B.
Regards Norma
May 27, 2008 | Ventamatic Gable Mount Power Attic...
Lost key
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
May 22, 2008 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
471 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
