Question about Sony Playstation 3 (PS3) Console
PS3 cd drive spindle moter is broken!! need replacement
What should i do if my PS3 Dvd drive spindle moter is not working?
i first thought it was the optical laser.... but after taking it apart im sure it is not
I bought this PS3 from a 3rd party without a warranty so please dont waste both of our time and tell me to just send it into sony
i was thinking of buying a new Cd drive replacement which costs around $100, but there are two versions. One being kar410-aca and another kar400-aaa( not the correct spelling)
and if it is possible to buy another optical drive from another product?
Thank you
    President:
  • 2,653 Answers
You have to use the same one. There are only two kinds: single laser, dual laser. (kes-400a / kes-410)
The laser is the problem, not the motor. the motor won't spin because the laser has to be in working condition. sounds weird, I know....but that's just the way it is.
Let me know if you have any other questions.
Posted on Nov 20, 2009
What if the laser is workin took mine apart and i can see the laser movin back and forth and i see the laser tryin to read the disc.can i just replace spindle motor and if so how mine is the kem 410aca backwards compatible
Posted on Oct 02, 2012
    Problem Solver:
  • 5 Answers
I need to replace my lens in my PS3 but have seen a couple of model types. KEM 400 AAA or KES 410 ACA Can some one please tell me which one...
LOOK AT THE BOTTOM OF YOUR PS3 FOR THE MODEL TYPE.. THEN TYPE THAT MODEL INTO EBAY SEARCH FIELD TO SEE ITEM NUMBERS.. SINGLE EYE IS THE OLDER VERSION DUAL EYE IS THE NEWER VERSION AND CHEAPER.. REPLACE BOTH LENS AND SPINDLE SO YOU DONT HAVE TO OPEN IT AGAIN AFTER YOU GET IT FIXED..
Posted on Jun 16, 2012
  • Triple Ace Comps Jun 16, 2012
    LOOK AT THE BOTTOM OF YOUR PS3 FOR THE MODEL TYPE.. THEN TYPE THAT MODEL INTO EBAY SEARCH FIELD TO SEE ITEM NUMBERS.. (400)SINGLE EYE IS THE OLDER VERSION.. (410) DUAL EYE IS THE NEWER VERSION AND CHEAPER.. REPLACE BOTH ($11-$40)LENS AND ($5-$15)SPINDLE SO YOU DONT HAVE TO OPEN IT AGAIN AFTER YOU GET IT FIXED..
My SANYO CD player rumbles when I try to play a CD and it worked before when I used it
the video was a great idea but it appears the disc is moving while it trying to read the table of contents to continue into play ?
the spindle hub is loose or broken is my guess at this point it was dark in play back and that is what it looked like
the hub would have to be replaced if im correct im sure it can be ordered or a after market replacement
one thought is the height of its placement is critical to the disc being read for playback or the whole cd pickup with spindle motor should be available as a replacement and the
Oct 04, 2012 | Televison & Video
Rotating plastic disc holding component on spindle broken where would i get replacement
A computer technician may have an old drive with a good plastic rotating disk that will work in your drive. He/she would simply use an old drive to repair your drive. If that option is not available to you then a whole new CD/DVD drive needs to be installed.
Contact a laptop computer technician or a computer store.
Take care!
damnor01
Aug 14, 2011 | Toshiba Satellite A105 Notebook
Dvr cd drive won't play cds get message asking to insert a disc when one is already inserted
Your cd drive is damage, the laser head or the spindle is not functioning and is not reading the disc thus causing the message of no cd being insert to appear, however the cd-drive power is still working which the computer is able to still detect, but like I said earlier the spindle/laser head is malfuction. You will need to replace the entire cd rom drive. If you don't know how to replace it, an external cd/dvd drive will also do the job.
Jan 30, 2011 | Dell Inspiron 531s Desktop Computer
My ps3 makes a grinding noise when i put in a cd and it wont read any cds
Spindle bearing has worn or
Debris inside the drive clogging up the spindle
Or damage to the drive belt
Removal and checking / replacement is advised
Jan 27, 2011 | Computers & Internet
Ps3 not spinning disc, replaced spindle motor, did not fix. Please help
Hi there, this is because the actual laser needs replacing, not the disc spinner motor. With the PS3 the laser reads the disc data type, whether it be a DVD, game , audio cd or blu ray movie. It then spins the disc up to the required read speed. When the laser is faulty is cannot read the disc type so will not spin at all.
Hope this helps
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Dvd writer's flap not going in..
Breaking of cd indicates that the cd is not aligned (tightened) properly between the spindle and the magnetic top, if the tray dos'nt align properly it may not lift the spindle up, open the drive and check for any obstacles in the tray path, important if your drive uses rubber belt to drive the tray in-out replace the belt, also check the magnetic top for breakage.
Jul 24, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
Turns on, but will not play or recognize DVD
The spindle motor motor is defecteive already. replace it. when the spindle motor not working. the cd wont spin, how can the optical lens read the disc when its is not spining. you need a qualified technician to fix your problem.
Jun 27, 2010 | Insignia IS-PDO40922 Portable DVD Player
The cd-rom drive in my computer has stopped working all of a sudden. The cables inside the tower are all connected however it does not recognize a disc being in the cd-rom drive! I also get a warning that...
Replace the Cd-rom drive, sounds like you may have a bad spindle motor and or Laser assembly. Cd-roms are very cheap these days, and you might consider replacing it with a DVD drive instead, which is downward compatiable.
Sep 28, 2009 | Gateway GM5084 PC Desktop
My Equium laptop will not play audio cds-starts then cuts off.dvds still work.
The laser lenses of the CD and DVD are different.
If you have already updated the firmware of that CD/DVD drive the solution is replace that drive.
Feb 20, 2009 | Computers & Internet
Spindle for cd drive broken
I'd suggest you change the drive,, DVD DRIVES FOR LAPTOPS are usually standered parts Take the drive out and buy one and replace it. I dont think you laptop might require a special drive Laptop usually carry standered drives meaning any one should work.
Dec 26, 2007 | Dell (M6790) DVD RW Burner
Sony Playstation 3 (PS3) Console Logo
1,231 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
