How to save file at cctv camera - Computers & Internet
    Sniper:
  • 50 Answers
First of all you install camera software (net sink) it’s free on net, in this installation you give destination path where you want to save the data.
And after this installation you can able to save file at CCTV camera
Thanks& Regard
Abhay Singh
Posted on Nov 23, 2009
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Sentient dvr cctv playback
Hi, I have a maplins sentient model Sentient dvr cctv is there a windows 7 PCviewer programe ?
Mar 30, 2010 | Computers & Internet
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Cctv camera wire pulled off
a simple web search for "scart socket connections" will find details of what signals each pin of a scart connector carry. however, your problem is knowing what signals the wires from your cctv camera carry. only the camera manufacturer, or a service engineer familiar with it, can tell you that.
Aug 18, 2009 | Home Security
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
