Question about Whirlpool Refrigerators
How to turn off the ice maker, Model # ET18PK It looks like the wire gizmo will shut it off when the ice tub is full. So I pile boxes under the gizmo to tell it to shut off, but no, the ice cubes pour out over the boxes, out of the ice tub, etc. I empty out the ice and try again with different interaction with the wire gizmo.
  • 999 Answers
The wire(Bail) should lift and lock in the full up, (horizontal) position. If it will not stay up the switch is broken and that is why it will not stop.
Eric
Posted on Nov 19, 2009
Testimonial: "Thanks, Eric You've said what's wrong, but not whether I can fix it myself. I've taped the bail with strong tape, unsure if it will hold in freezer. "
Cannot get ice maker to dispense ice.
Many ice makers have a lever kind of gizmo (often looks like it is made from coat hanger wire) that is pushed up when tray is full of cubes, thus turning off the ice maker. Make sure the lever is in the down position.
Jul 20, 2017 | Refrigerators
Ice maker is not making ice. what could be the problem?
The two most common things that happen: the ice piles up too high, which pushes up the bar that tells it the bin is full and stop making ice. OR the ice sticks to the ice cube maker. If the ice pile is too high, knock it down or empty the bin. If the ice is sticking to the cube maker, try melting it and then spraying it with a non stick spray. Sometimes the water supply line is clogged, but that is not usually the problem.
Feb 28, 2015 | Refrigerators
The model for Scotsman ice maker is AFE400A-1B and it stop making ice. Can you help me diagnosis?
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Mar 15, 2011 | Scotsman Ice Maker WBin Flake Style water...
Ice maker not working
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Also note that,
Sounds like the thermistor is bad in the ice maker itself, and there are 3 more micro switches, and some other things in there too, just easier too replace ice maker than parts for it.
If it turns out to be the ice maker, look on the tag in the ref. side, which list the model number and serial number. look @ bottom of that tag, it will give you a model number for the ice maker kit you need.
Good luck and hope this helpout......
Jul 30, 2010 | LG LFX25971ST Bottom Freezer French Door...
Unit is off due to maximum harvest, what does that mean
The ice bucket is full, or the sensor arm (wire) is stuck in the UP position. It thinks that ice is piled up high...
Sep 22, 2009 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Model #36378285890 The ice maker will not shut off keeps dropping ice.
On mine the ice detection arm gets jammed with ice piled up so that it doesn't swing up. This in turn makes the machine think there's not enough ice, and it will overfill. Also, when it does catch some ice under it it will hold on to the ice, thinking it's full, when the catch bucket is depleted.
The fix would be a stronger motor on the arm enabling it to break through the ice. Costly.
We monitor the ice level, and just lift or drop the arm as required. A small price to pay.
You do know that Kenmore does not make appliances. They contract out to folks like Frigidaire and put the Kenmore name on it.
Sep 20, 2009 | Kenmore Refrigerators
Kenmore Elite, Ice maker will not produce.
Try taking the ice despenser out and carefully melt any ice in the freezing tray. Sometimes the ice doesn't fully eject, leaving behind residue that will eventually become too full to produce ice. You can melt it by slow running hot water or hair dryer low speed.
Aug 07, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Ice maker not making ice
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice Maker
Replace the ice maker.
Sep 21, 2007 | Refrigerators
Refrigerators Logo
112 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
