Question about ViewSonic VA2226w 22" Widescreen LCD Monitor
I have a ViewSonic VA2226w 22-inch Wide LCD monitor and just last night it had problems where the screen is faded out on the left side (vertically) and all my icons were a bit faded with horizontal white lines on the right side, like it was a cartoon running ( I guess it would fall under the cataglory of ghosts on the screen. I tried downloading and installing the latest drivers and that seem to help, but as time progressed the problem came back, but not as extreme. I generally shut the monitor when I don't use it, but I sometimes forget. Overnight the problem was gone. How do I fix this problem, I know it's gone for now, but it may be back in an hour.
  • 3 Answers
Its a panel problem. You need to change your monitor panel or you have to buy another one :( and if it has warranty left then go to the servicing center
Posted on Apr 05, 2017
  • 3 Answers
Just take all IMP apps and doacuments and format it
all c drive
5 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Posted on Oct 10, 2008
budmrtn
  • 11361 Answers
SOURCE: my viewsonic
You may have problem in the power supply, see my pictures here so you will know what to look for if you want to DIY: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Hopefully not the LCD panel (I never have to replace one yet in this model).
Posted on Apr 18, 2010
budmrtn
  • 11361 Answers
SOURCE: Mouse movement is not clearly visible & get more H'lin brightness
Have somebody take a look at the capacitors in the power supply first, look for caps that are leaking/bulging top, very common failure in LCD monitor.
Please see some failed bad caps album and failed VIEWSONIC monitors due to bad caps here:
http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps:
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 01, 2010
SuperTech-11
  • 1591 Answers
SOURCE: Viewsonic - VA2226w - dual
Swap this monitor with the main one.
If it works, you may simply not have the secondary output enabled in the operating system.
In Windows for example, in the video properties, there's a place where you choose which video card you're dealing with (and/or which output or monitor) and there's a checkbox that says "extend my desktop to this monitor"
If that's not enabled, monitor 2 will be blank !
If the monitor doesn't work in the same connector that the working monitor is in, you may have bad capacitors in this one.
Watch the video below on how to fix that issue.
Posted on Mar 25, 2011
Testimonial: "Thanks, great answer, I believe this is my problem and give it a try."
We have a Viewsonic VA2226W that goes to black screen after 15 seconds or so, is it toast or is there a way to fix?ViewSonic monitor VA2226w
Make sure you are supplying a valid timing mode to the display. Call ViewSonic technical support to resolve your issue.
Oct 01, 2014 | ViewSonic VA2226w 22" Widescreen LCD...
Can I fix a flickering band on VP2250wb?
It sounds like one of the backlights are going, or one of the inverter transformer and there are two capacitors near the inverter transformers that do give trouble. The monitor would need to be dismantled to investigate the problem and it will involve money, since it is four years old I would be inclined leave it alone until a new one is required.
Apr 15, 2012 | ViewSonic VP2250wb LCD Monitor
Viewsonic - VA2226w - dual monitor configuration. Monitor is black / no image- all test pass showing monitor is functioning properly.
Mar 25, 2011 | ViewSonic VA2226w 22" Widescreen LCD...
Jun 01, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
Apr 24, 2010 | ViewSonic VX1932wm Monitor
After waking from sleep mode, monitor resolution is a mess!
Try reinstalling the graphics drivers. and possibly a different graphics card.
Apr 14, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226W LCD Monitor unlock power button
Try holding the vol+ & vol- or hold the vol+ & Menu and lastly try the ch+ & ch- buttons. When doing this you must do it from the tv not the remote, and hold them down for ten seconds or until it says it has unlocked.
Apr 04, 2010 | ViewSonic VA2226W LCD Monitor
When Monitor has been switched off for 8 hours it takes 5 minutes to get back up again. Once up it will work perfectlt
This monitor is more than 2 years old, time to look for bad caps with bulging top in the power supply, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
Installing Ubuntu after vista install gives "out of range"
http://www.tech-tips-now.com/2008/11/12/how-to-dual-boot-vista-and-ubuntu-810-part-7/
this is great guide to set up a dual boot option on your on pc
Mar 16, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226w 22" Widescreen LCD Monitor Logo
196 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
