Hello Two days ago web images and logos on this PC/monitor started becoming fuzzy/pixelated. Also, web pages load slowly. Problem is seen with different browsers also. Desktop environment appearance is OK. Photoshop images appear OK. Web pages viewed on (different) laptop wirelessly connected via same router are OK. Have uninstalled and reinstalled vga driver (your recommendation). The problem is still here. (By way of more info, this type is perfectly clear. ''165 Experts are Online Now!'' is perfectly clear. The man in the suit (right of screen) is a bit fuzzy. ''FixYa'' logo at the top is fuzzy. Very small print at bottom of this page is clear. ''BBB Accredited Business'' logo to bottom left is fuzzy''. What shall I try next please?
  • 187 Answers
1)Go to Control Panel>Appearance and themes>display>settings>Make sure your screen resolution is set to more than 1024X768 and millions of colors.
You didn't download an accelerator for a modem, did you? If so, that is usually how the accelerator works, by deducting pixels from graphics. If that is the case, go to your accelerator and choose use original image settings. The other place we need to look is in browser settings and internet connections. See pics below. Make sure that compression settings are not too high.
2) clear your cache, cookies, and history.Instructions differ, but go to control panel>network settings>internet options. You can also check on your internet connection.
Lastly, if you have been making graphics for the web with Adobe, or another web program, make sure that you haven't changed your view settings in an effort to conserve memory in your editing programs. Sorry if I gave you redundant advice, I couldn't find your first post. Thanks, please continue to leave comments if your situation changes.
Text and graphics are totally different, so browse through you internet settings to make sure that you didn't accidentally changed something. You can choose reset original tools/option settings in browsers and Adobe if you are not sure where the problem comes from.
Posted on Nov 19, 2009
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
Tip
Hyperlinked image on your facebook page using FMBL
To add a hyperlinked image to your fan page for a logo OR some other use follow these easy steps:
  • Make sure you’ve installed the staticFBML application
  • Make sure your image is the right size (max 160 pixels wide) you can resize this in either Adobe Photoshop OR similar package.
  • Load your image into a photo album on facebook even your own web server if you have one I use ImageShack for ease
  • Check out my tip HERE for help with adding SWF to your facebook page and weblogs.
To make the image appear on your fan page wall, follow these steps:
First go to your fan page and click Edit Page (just below your fan page picture)
Click the pencil icon on the right of the FBML application in your list of applications, shown here are two that I have already created.
Add the Title you want displayed above your image/icon/logo then in the FBML area, paste the following code, replacing the items in between the ” to reflect your image. Note you mayneed to can change or delete the width and height information.
<img src=”http://www.YOUR-IMAGE-URL.com/IMAGE-NAME.jpg” title=”YOUR IMAGE TITLE” width=”130′ height=”130′><br>
I have shrunk the screendump for ease, this window is much bigger. If you can't get this to work on your FMBL I have included an example below for you to test.
<a href=”http://www.retaggr.com/page/SpideRaY” target=”_blank”><img src=”http://img441.imageshack.us/i/retaggr.jpg” title=”Retagger Profile” width=”187′ height=”70′ /></a><br >
on Jul 05, 2010 | Facebook Social Network
What disavantage about LCD?
The most notable disadvantage to LCD screens is their fixed or native resolution. An LCD screen can only display the number of pixels in its matrix and no more or less. It can display a lower resolution in one of two ways. Using only a fraction of the total pixels on the display or through extrapolation. Extrapolation is a method whereby the monitor blends multiple pixels together to simulate a single smaller pixel. This can often lead to a blurry or fuzzy image particularly with text when running the screen below is native resolution.
Video was problematic with early LCD monitors because of lower response times. This has been overcome by many improvements, but there are some that still have low response times. Purchasers should be aware of this when purchasing a monitor. However, the improvements are often work arounds that can actually lead to another problem of reduced color clarity. Unfortunately, the industry is very poor about properly listing the specifications for monitors to help buyers understand and compare monitors.
  • Blurry images Outside Native Resolution
  • Motion Blur on Fast Moving images
  • Some Models Have Reduced Color Clarity
Conclusions At this point and time, most consumers will likely be purchasing LCD monitors over CRTs. There is almost no difference in the cost to consumers thanks to production improvements in LCDs and the reduction in the production of CRTs. Typically CRTs will only be seen sold with the least expensive of desktop computer systems or by those with special imaging needs such as graphics and medical professionals.
Mar 04, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Wanting to find out if my monitor is going out, or if theres
From what you are describing this is not a monitor issue. If the monitor were dying you'd see faults in the images, dead pixels, or random poweroffs. Loading windows slowly has nothing to do with your monitor. It is likely that you have picked up some sort of virus, spyware or malware that is slowing your system down. Have you installed any toolbars in your web browser lately? Those are notorious for ruining PC performance.
Dec 31, 2009 | ViewSonic VA1930WM LCD Monitor
Fuzzy display
It could be that the crystals in the LCD are frozen, which has been known to happen in Defective Models. I recommend a New LCD. If it still works on a external monitor it is not a Video Card. Also, if you want to try a cheaper alternative, try just replacing the device under the LCD, which controls Color and Brightness. Google it, the name varies with people, so i cannot name it.
Dec 22, 2009 | Acer Aspire 9300 Notebook
Web loading and image problem
hi
try this :
- firs you should have the correct video card drive or cd
-go to Hardware>device Manager>display adapter
- right click the vga card>then uninstall
- this will delete vga drivers (which is for some reason not functioning well)
- reboot windows
-after reboot windows my detect the vga card and starts a wizard
to define the vga chip. make sure at this point that the path for the driver is your cd or driver folder (not driver cach) because it will restore same corrupted files.
hopefully this shoud work it out
Nov 19, 2009 | Computers & Internet
Text is blurred
The problem is with text font size and image resolution. These two are married together. In other words one supports or hinders what the look of the end result will be. Increase the pixel depth of the image and then insert your text with a larger font size and the result should be clearer. As you may know, when you enter text it becomes another layer in your image. Once the object in this layer is created it can be resized. And, resizing may be the answer to get the font size you actually want and a crisp, no pixelated, edge for your type face.
Can you exchange messages with me over the next 12-24 hours as I give you a tutorial with your current project?
I have a business to run myself and just so happens that today and tomorrow I'm pretty busy. But, I've taught this software in version 7 at our community college a few years ago and help local clients all the time with PSP.
Regards,
Worldvet
May 21, 2008 | Corel Paint Shop Pro 9
Monitor issue
Look to Caps on the inverter if its an LCD or flat pan. monitor.. Weve seen this be4..
Jan 13, 2008 | Norcent Technologies LM-762 17" Monitor
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
