TV picture won't stop blinking
This tv is about 12 yeas old. It started to take a long time to turn on one day and began to blink periodically. It continually got worse and now it takes at least an hour to turn on and blinks every second. The sound is perfectly fine. What's wrong with it and Is it worth the repair cost or part replacement? Thanks.
  • altima4584 Jan 11, 2008
    It's a Sony Trinitron KV-32S20 and 32 inches.
  • 8,617 Answers
Sounds like a bad solder joint or leaky capacitor. What make and model set do you have.
Posted on Jan 11, 2008
  • Sonny Berry
    Sonny Berry Jan 11, 2008
    I would check for bad solder around the Flyback, Horizontal drive transformer as well as the vertcle IC , and horizontal and verticle yoke plugs. The TV is definatly worth repairing. If the solder looks good I would suspect some faulty capacitors.
Sony trinitron tv
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 10, 2017 | Televison & Video
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Mar 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv is blinking on and off
I think you have a bad capacitor in the power supply circuit. You need to have a certified technician look at it though. Get someone who is familiar with mitsu's though. Have a great day. Jay
Jun 06, 2010 | Mitsubishi WS-65311 65" Rear Projection...
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
20" Trinitron Wega
Good day.
First, Have your tv 's circuitry be resoldered. this might be a case of loose contacts particularly along the crt circuitry. the longer you operate the unit at this condition, the faster you are counting the possibility of shortening the lifespan of your tube. 9 years is quite a young age for a unit which has an average of 18years.
response is highly appreciated.
chris
Mar 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Power light blinks
I found a solution, Heat. When the set is on and heats up it stays on, but once off for the night it gets cold and can't start, try using a hair dryer on full blast and put the heat around the back top vent like structure and wait for the light to stop blinking, this only takes about 2 min or so
Sep 05, 2007 | Samsung LTN1565 15 in. HD-Ready LCD...
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
