Trying to place my Aspire X3810 motherboard in a different case. once its set up i find that the power switch in my case is different than the power switch in the old case and I cant figure out how to make it work
    Brigadier General:
  • 3,513 Answers
Hi
From the power switch usually two cables come out,you need to connect those cables to the motherboard,if that is not feasible then you cant adjust your motherboard in a new case..as no such connecters are available in the market for this.
Thanks for contacting fixya.com
Posted on Nov 19, 2009
Aspire x3810
make sure at you replace a ATX-card whit a ATX.the cards messurment have to be the same.
May 20, 2013 | Computers & Internet
No beep at start up
Could be a grounding issue. Remove the mother board from the case, and place on a piece of cardboard. Plug in the power supply, memory, monitor and power switch if it will reach (if not then you will need to short the jumper were the power switch plugs in with a small screw driver). Once set up, power on the mother board, you should get a no hard drive error, since we did not plug it in. If this does work, you will need to go the hardware store and pick up some rubber or paper washer to place between the mother board and the case.
Feb 22, 2012 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Acer aspire x3810 will not switch on properly - monitor registers "no signal" and then goes into standby
Try a known working monitor. The onboard video may be defective and you may need to buy a video card. Take out the memory and reseat it, as it may have gotten loose. I hope this helps. Good luck and have a great day.
May 01, 2011 | Computers & Internet
M5640 power comes on no video. changed motherboard and power supply
I assume you are using the integrated video, (on board). With a new power supply and motherboard you have eliminated all but the monitor. Try a different monitor. I have also seen a case where a computer tower worked fine in one setup with a flat screen, but when hooked up to an older CRT monitor it would not display because of the resolution settings.
Apr 07, 2011 | Acer Aspire m5640 PC Desktop
Trying to find my aspire T180 factory setting password so i can take it back to factory setting
first power off your system remove the cover in the motherboard remove the small battery and switch on the computer while doing make sure all the hard disk and cd rom power has to be removed then place back the battery in the compartment then switch on the system press Del button and enter the correct date and time then click save and exit then connect the HDD and cd drive power and switch on the computer your computer is now set to factory defaults
Feb 26, 2011 | Acer Aspire™ T180 PC Desktop
Where do i plug in the components from the computer case on my motherboard?
There are a few things you will need to plug: HDD LED, POWER LED, POWER SWITCH, RESET SWITCH. There are others such as USB and Audio. All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located near the battery on your motherboard. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND].
Feb 21, 2010 | Aspire X-DISCOVERY-AL ATX Mid-Tower Case
Im trying to install dell i530 into Xion II case but cant figure out how the power switch led hooks up?
All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located at the very bottom. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. All of the switches and LED pins will be different on different motherboards. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND]. USB and audio will always be the same.
Feb 17, 2010 | XION II Black Pearl ATX Mid-Tower Case
Aspire m-5620 desktop shut down wont power up
Try opening the computers case and resetting the BIOS Battery
Now BEFORE you open the computer do the following:-
(1 Unplug the computer from ALL conections (2 Touch the metal case on the computer to get rid of any static electricity. Static + Computer = Dead Computer so be sure not 2 have static electricity when operating on computer.
Now we may begin!
Now once you open your computer find some thing called the BIOS Battery. Now it's a CR2032 Battery which is the type people use in tamagotchis and pocket LED lights. It will be silver and round and about the size of a camera lens. Now find a clip or something holding it in place. Push that clip and the battery will pop out. AVoid touching the motherboard witch is the big board that the BIOS Battery is on. It wont damage anything by touching it by just try not to.
Now wait about an hour.
Once youve waited around an hour put the BIOS Battery back in. Switch on your computer and hey presto we have bootup. Now your computer will say something like press F2 to setup BIOS or Press Escape to run deafult settings. Just stick with the deafult settings.
Jan 20, 2010 | Acer Computers & Internet
Long beeb sound
find out what brand your motherboard is and look for the beep codes, each motherboard is different but these beeps are there to tell you the problem. if it isnt turning on when you press the button it is most likely a power supply problem like you said and you should try reconnecting all the power connectors to the motherboard and make sure everything is in place. also look for the voltage switch on the back and make sure it isn't at the wrong voltage that has happened to me more than once ;)
Dec 13, 2008 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
