Question about Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 software update locks up computer, update is about 2 Gig. locks up computer every time I try and run it, only way out is hold in power button.
    Guru:
  • 1,738 Answers
First try shutting down your firewall then try. The update could be to big for your unit. Try updating buy smaller sizes.
Posted on Nov 21, 2009
Need to update maps on my garmin nuvi 205
If you are referring to updating the firmware, you should go to Garmin's website, www.garmin.com and download the WebUpdater software first. Once that is installed, plug your unit into your computer and then run the software.
Jul 11, 2010 | Garmin nuvi 205 GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Hard Reset your Garmin Nuvi 205W (Mark 2b)
Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205W GPS Receiver
Garmin nuvi® 205 Car GPS Receiver Try to recalibrate and it is frozen
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then I suggest a hard reset.
Finally, replace the firmware and system software using webupdate.
Replacing the firmware should allow it to power up successfully after the update.
I hope that helps.
Mar 28, 2010 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 205 gps trouble shooting will not power on
If your Garmin NUVI 205 can be recognized by your computer when it is plugged in, I recommend you backup your favorites. Then I suggest a hard reset.
Your Nuvi should not need to be able to power up for a firmware update to be possible - replacing the firmware should allow it to power up successfully after the update.
I hope that helps.
Mar 23, 2010 | Garmin nuvi 205 GPS Receiver
Tip
Perform a Hard Reset of your Garmin Nuvi 205 (Mark 2a)
Perform a Hard Reset of your Garmin Nuvi 205 and 205W
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205 GPS Receiver
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W (Mark 2a
How to Perform a Hard Reset of your Garmin Nuvi 205W
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It is generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Your Favorites:
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
I hope that helps.
Garmin nuvi 205 series, keeps beeping and "loading maps" I tried shutting it off and then holding the reset and turn it back on. it will not turn back on this way. if i push reset w/it on, it shuts off.
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
These are both good steps to take when a Nuvi starts acting up.
I hope that helps.
Dec 21, 2009 | Garmin nuvi 205 GPS Receiver
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Tip
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
I hope that helps.
_______________________________________
Download Garmin Nuvi 205 Manuals here.
Garmin Nuvi 205 Favorites Backup here.
Garmin Nuvi 205 WebUpdater here.
on Jan 15, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
214 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
