Question about Silverstone (sst-tj05-b) ATX Mid-Tower Case
Damaged usb ports, need side i/o panel with usb, 1394, and sound connections that comes with case. Case is silverstone tj05 and is still being sold new although it has been discontinued. On a high end case parts should be available. The certainly are with Antec. Silverstone is only as good as it support for parts and service and right now that doesn't seem so good.
    Brigadier General:
  • 10,406 Answers
Thanks for the information.
Posted on Nov 19, 2009
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
For some reason the computer cannot find or recognise my camera and keeps saying communication error ?
Ok. there're three possible causes for this. I'll list them and the relevant procedures of resolution by probability of occurrence.
  1. Damaged data cable- (confirmed if the following 2 doesn't fix the problem) if this is the case, you need to get a new cable.
  2. Damaged USB port on computer- Confirm by trying to connect cam to a different port (i.e.- try the rear ports if you were using one on the front) or to a different computer. If this is the case, you need to get a USB expansion card that will give your computer some extra USB ports.
  3. Damage on camera's side (could range from a simple broken port tab to circuit damage) confirm by: connecting a different camera to your computer using the same data cable. If this is the case you will have to take the camera to where you bought it from for repair (remember to check whether you can still claim your warranty.)
Sep 25, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Can it be used as external hdd
Yes it can be used as an external hdd.
This is the only procedure i know and i hope you'll be satisfied.
Things You'll Need
Screwdriver
Locate and purchase an IDE to USB cable conversion kit. Insert the driver CD that came with the kit into your computer's CD drive. Follow the instructions on the installation prompt that will appear on your computer's screen to install the conversion cable driver software.
Power off the computer once the driver software has finished installing. Remove the power cable and all of the other cords from their ports on the back side of the computer.
Set the entire computer case on its side so that the left side panel is facing upwards. Check the back end of the case to determine if the side panel is locked with two case screws or only a metal latch. Disconnect the panel from the case either by removing the screws or by pulling upwards on the latch.
An IDE Cable
Pull the side panel off of the computer case and set it aside. Locate the drive that you want to connect with a USB cable. Remove the screws holding the drive into the drive bay. Disconnect one end of the IDE cable from the motherboard, but leave the other end connected to the back side of the drive itself.
5
Remove the drive from the drive bay with its connected IDE cable and set it outside of the computer case. Set the side panel back onto the case and re-attach the metal latch or case screws. Plug the cables back into the computer ports and power the computer back on.
6
Insert the end of the IDE cable that used to be connected to the motherboard into the IDE port on the conversion cable. Plug the male USB end at the other side of the conversion cable into any open USB port on your computer.
Have a nice day friend and i hope this would satisfy your needs.
Aug 20, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Damaged USB ports.
technically usb in case is wired in motherboard
Jul 10, 2009 | Cooler Master (CAC-T05-WWC)
Can't drive av/c;multimedia hardwares;tvcard
Sounds like the card reader cables, USB cables, and Firewire, (1394) cables have been disconnected from the motherboard. I'm guessing granted, but it could have been when the TV card was removed, or perhaps when you were installing upgrades.
You've had the computer open, judging from the statement that you've upgraded it.
1.Computer off, and unplugged from the surge protector. Open the computer case. TOUCH the metal frame of the computer case, to relieve your body of static electricity.
2.You may have to use a flashlight. Look for the cables coming from the card reader. From the Front Panel. You may have to remove the Front Panel a bit, to peer in, and see which cables go to the card reader.
Finding these cables, follow them back to the motherboard. See if they're plugged in, plugged in tight, and if they are the right way around.
Do the same for the firewire ports, and the USB ports. Follow their cables.
Apr 29, 2009 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Jan 22, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Acer travelmate(belongs to my grandson), one rear usb three side mounted. Rear socket had been damaged, plastic contact support missing, pins touching case. Before I looked at it, notebook crashed if any...
motherboard dont have fuse has diodes which act similar to fuses but wont be blown.only things that will blow in that area are transistors or capacitors;but if these were blown usb's would not be detected.
in device manager were its says working correctly it relates to software istalled and working properly it cant tell u that the hub connection is damaged internally.
if your usb's are on card and connected to motherboard they can be replaced otherwise if built into motherboard youll have to take it to repair shop.
if the only problem is when u connect a usb device and not causing any other problems,u could use usb hubs that go into the pcmcia
Mar 30, 2008 | Acer TravelMate 2300 Notebook
MSI 915o comboAudio front panel
Some cases come with a Mic & speaker jack/ cable. These jacks sit within the case. Rather than using the rear Mic which is (colored pink) & speaker (colored green). These 2 colored cables run from the front of the case & out through an emty hole in the back of the case. Which you connect them to the rear of the boards Mic in (pink) & sound (green). Now you can use your front audio jacks for both mic & sound. This may sound strange but I have come across many cases just like this. Its not uncommon to have 2 front usbs & a 1394 connect on to the board as well. Without your manual I'm sorry I can not help you fauther.
Jan 02, 2008 | MSI 915P Combo-FR Motherboard
Silverstone (sst-tj05-b) ATX Mid-Tower Case Logo
114 people viewed this question
Top Silverstone Computers & Internet Experts
David Payne
David Payne
Are you a Silverstone Computer and Internet Expert? Answer questions, earn points and help others
