Question about SuperMicro X7DVL-I Motherboard
The mother board will not post nor will the display initialize on a X7DVL-I Supermicro board.
    Brigadier General:
  • 10,406 Answers
Is the on/off button on the front of the computer-casing broken?
Take a volt-meter, and run a continuity-test.
Are the two wires from that button both properly connected to a pair of pins on the motherboard? If you disconnect the wires from those pins, and use a metal screwdriver to very briefly "short" the two pins, to simulate the pushing of the ON/OFF button, does the motherboard post? Do fans start to spin, or at least "twitch" a few degrees?
Have you tried a different power-supply?
Is there any lamp on the motherboard that lights-up anytime that
the power-supply is connected to AC power? Is that lamp on?
Posted on Nov 19, 2009
Configure graphics card
That graphics card is not compatible with that mobo.
Nov 27, 2017 | SuperMicro X7DVL-E Server Board -...
Supermicro system initializing
The POST process is documented in the user manual under BIOS Post Codes.
Jan 31, 2013 | SuperMicro Computers & Internet
Intel d915GLVG mother board vrm is short and fun dose not work
An electrolytic capacitor has failed.
If one has failed it indicates that the board has overheated, and many other components are also weak.
This Intel board is not of good quality.
Replace with SuperMicro or Tyan, and improve the cooling airflow in the case.
Jul 01, 2012 | SuperMicro Computers & Internet
PC locks up at Supermicro splash screen during warm boot
Check for a post error in the bottom right of the display. It will be 2 letters or numbers. You can refer to the manual to see what the exact issue is:
Super Micro Computer Inc Products Motherboards Core 2 Boards C2SBX
However, the most likely culprit is RAM. I would try booting with 1 stick (and try all 4 dim slots) to see isolate the issue.
Oct 04, 2011 | SuperMicro C2SBX Workstation Board C2SBX+B...
Supermicro x6da8 won't post. Can't get into BIOS either.
disconnect all power connections to the board and take the battery out for a few minutes and then put it all back and see if you can acess the bios. If you still cant, try a bios flash and if that brings you no joy, board is done
Jun 27, 2009 | GE Supermicro X6DA8-G E7525 EM64T S604...
My supermicro mother board can not pick this type of SDRAM PC133U-333-542, meanwhile the memory slot is SDRAM
You are using the wrong memory.
A SuperMicro 370DLE only supports registered memory.
The U in the code shows that the memory you have installed is unregistered.
It will not work.
Exchange the memory for registered memory ,and the system should work fine.
Nov 19, 2008 | SuperMicro (370DLEO) Motherboard
Drivrs download
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
98
Aug 13, 2008 | Intel D845GVSR Motherboard
Dead motherborad
mkjameel
all mother board bios has a beep coad for successful post. looks at mother board manual which is provided with ur mother board. or vander web site. (some mother board one single beep for successful post).
thanks
Buddhadev
Jul 08, 2008 | HP (D7580-60003) Motherboard
WHICH MOTHER BOARD SUPPORT em64T INTEL ?
All major motherboard manufacturers offer this support on most boards. The em64T indicates the processor is capable of running 64-bit operating systems and software. Do you already have a processor and if so what model is the processor? Based on the processor model you'll need to select a motherboard that has the correct socket type and bus speeds.
May 02, 2008 | GE Supermicro X6DA8-G E7525 EM64T S604...
SuperMicro X7DVL-I Motherboard Logo
201 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
