Question about HP Photosmart 3210 Printer
How do I turn old negatives that won't fit the holder into photos? They are 3.5" x 2" or 82 x 57 mm for you kids!
    Sergeant:
  • 309 Answers
That model does not support scanning those size negatives - only 35mm strips or slides.
Posted on Nov 19, 2009
One big end knocking, Stripped, replaced bearing. same as old in size, no wear old bearing or crankshaft. PINK bearing fitted does is RED or YELLOW smaller clearence how much difference?
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594"- 0.0593"
Black 1.507-1.504 mm 0.0593"- 0.0592"
Brown1.504-1.501 mm 0.0592"- 0.0591"
Green1.501-1.498 mm 0.0591"- 0.0590"
Yellow1.498-1.495 mm 0.0590"- 0.0589"
Pink 1.495-1.492 mm 0.0589"- 0.0587"
Red 1.492-1.489 mm 0.0587"- 0.0586"
Sep 15, 2015 | Yamaha Venture Xvz1300 Xvz 1300 Xvz1200...
The 35mm strips won,t fit in my holder how should I be inserting them in the holder
The holder that takes 35 mm negative strips on one side and 4, 35 mm slides on the other has a plastic frame that holds the 35 mm film in place. To load film you have to first remove that frame by putting your finger in the opening by the large "A" and popping that end up. The frame fits in only one direction and must be clipped back in by first engaging the two small fingers into openings at the end opposite to the "A" and the lowering the retainer down snapping the 3 sets of 3 clips as you work toward the "A".
Oct 11, 2014 | Epson Perfection V500 Flatbed Scanner
Prolectrix usb turntable
Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
Feb 27, 2014 | Audio Players & Recorders
How long can negatives last in a plastic sleeve?
It all depends on how well they are preserved and if they are stored properly. Properly stored negatives can last for generations. Although in a few generations or even the next one you're kids won't know what a negative is.
Sep 23, 2013 | Photography
Neutral switch location on 1994 VT600
Instructions
    • 1 Pull the left and right covers out of the rubber grommets on both sides of the motorcycle's frame. Pull the rubber strap off the tool kit holder on the left side of the motorcycle and remove the tool kit.
    • 2 Locate the fuse box on the right side of the motorcycle, just above the battery. Remove the pair of bolts that secure the fuse box to the battery box with a 10 mm socket. Pull the fuse box away from the battery box.
    • 3 Reach into the left side of the frame to access the battery's negative terminal. Unscrew the negative wire lead bolt from the battery's negative terminal with a 10 mm wrench. Pull the negative wiring lead away from the battery.
    • 4 Reach into the right side of the frame and remove the positive wiring lead bolt from the battery's positive terminal with a 10 mm wrench. Pull the positive wiring lead away from the battery.
    • 5 Pull the battery out of the battery box from the right side of the motorcycle. Slide a new YTX9-BS battery into the battery box, positioning the battery's positive terminal to the right of the motorcycle. Reconnect the wiring leads to the battery's terminals, connecting the negative lead first followed by the positive lead. Tighten the lead bolts with a 10 mm wrench.
    • 6 Reattach the fuse box to the battery and tighten both bolts with a 10 mm socket. Place the right side cover over the frame. Push the cover's tabs into the frame's rubber grommets.
    • 7 Place the tool kit into the tool kit holder on the left side of the motorcycle. Pull the rubber strap over the tool kit and hook the end of the strap onto the holder's catch tab. Place the left side side cover over the frame. Push the cover's tabs into the frame's rubber grommets.
Jan 16, 2013 | 1994 Honda VT 600 C Shadow
I would like to know whether there is some sort of attachment available to copy my photo slides and photo negatives to my PC?
There are several options but the most practical one is to get a scanner that scans transparencies. They are not cheap but are the most effective. Another option is to project the slides onto a special screen and then photograph them with a digital camera. This can be done with 35 mm negatives as well and then they can be turned into positives with software.
Jun 25, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
I have very old photos negatives and would like to turn them into digital photos. can you please tell me how? many thanks.
for old photos, just scan them in individually using a scanner or all-in-one priter with scanner. for the negatives, you need a scanner that can handle them like these
http://astore.amazon.co.uk/clivgraycomp-21/search?node=5&keywords=negative+scanner&x=0&y=0&preview=
May 30, 2011 | Computers & Internet
How to scan negatives & slides with the epson RX620
There are holders for the slides and negatives inside the top cover. Remove the white part and take out the holders. Place the slides or negatives in the holders and place on the glass plate. Then you choose the proper menu for copy or scan and follow the directions on the screen. I scanned quite a few slides and had no problem.
Sep 27, 2008 | Epson RX620 All-In-One InkJet Photo...
Scanned negatives are not sharp.
One workaround is this: use the holder for the negatives as a guide but not as a holder as such.
To do this, place the film negative directly on the glass plate, then put the negative holder (completely assembled) on top of it; align the film and the holder so that the frames on the filmstrip line up with the marks on the holder correctly.
Now, close the lid and follow the normal procedure for scanning negatives. They're noticeably sharper this way, suggesting that the scanner's focus is set for items placed directly on the glass plate. I have no idea why focus isn't adjusted correctly for negatives, which site a millimetre or two above the glass.
Aug 27, 2008 | Canon MP970 Photo All-In-One InkJet...
HP Photosmart 3210 Printer Logo
169 people viewed this question
Seeker5211
Seeker5211
