Question about Denon Audio Players & Recorders
CD DRAWER DOESNT OPEN
I have a Denon UD-M3 CD RECEIVER . the open and close button to the CD does not open ,When the button is pressed to the CD to play, it says Track 1 then sets to zero
    Sergeant:
  • 275 Answers
Is there a small hole on the front of the load tray? If there is use a straightened out paperclip to push into the hole to remove the stuck cd. That might help you out.
Posted on Nov 19, 2009
Denon CD Player Drawer won't open
This problem can be due to a defect in the player mechanism or binding in the drawer travel path. You may be able to find and correct the binding problem.
Jan 29, 2015 | Denon Audio Players & Recorders
Yamaha CRX-330 CD drawer won't open
I had the same problem. It opened when I gave the reciever a slight lift and let it dropp, after I pressed the Reject Button. It's not a solution but at least it's open.
Jan 10, 2014 | Yamaha CRX-330 CD receiver
How to set time on denon ud-m3
press 'display' for 4 sec, then change hr with left arror, min with right arrow. easy
Mar 26, 2012 | Denon CDR-M30 CD Recorder
Denon UD-M30 cd door will not open or close
hello! how u . this behavior is brought about by this factors i either the loading motor belt has worn out , 2,the loading motor is faulty not spinning ,3the CD tray is set wrongly so remove the tray and set it correctly for it to close and open .
good luck
Sep 08, 2009 | Audio Players & Recorders
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
Denon UD-M3 CD Receiver CD playing
Sounds like your spindle motor is shot. What happens is, the bushings in the motor that turns the CD disk are worn. So tilting the unit will change the loading of the motor shaft to an " un-worn" spot on the bushings and the CD plays properly. The spindle motors are chepa for the most part, but the labour might bite you a little because it is a fairly involved job. If the unit is still under warranty....great...if it is just off warranty, you may get some good will service from Denon......best of luck...Rob
Mar 31, 2008 | Denon DN-961FA CD Player
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
523 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
