Question about Cell Phones
Trackball not working when pressed down
I replaced my trackball. Will not work when I press down to choose an option. I removed the trackball, cleaned with alcohol. Rolls fine just won't click. If I push extremely hard, sometimes it will work.
    Sergeant:
  • 297 Answers
It's a problem in ur key pad.....clean it..........then it will work.......if there is still problem then u need to replace ur phone key pad paper
Posted on Nov 19, 2009
My blackberry curve trackball is not working property. I can move up and down but it does not work when I press to make choice.
Thank you for using FixYa
This is a known blackberry issue.
There are 2 options available: with a pin you can remove the trackball and clean the surrounding area of the track ball (NOT RECOMMENDED)
Being that it is a known issue, you can take the telephone to your phone provider and they should be able to replace the track ball.
If that does not solve the problem, you will need to have your telephone replaced
Jul 18, 2011 | AT&T Blackberry Curve 8300 Smartphone
trackball or trackpad?
Trackball can be taken out and cleaned, trackpad would be a replacement
May 24, 2010 | RIM BlackBerry Bold 9700 Smartphone
How can I make my trackwheel press? It is not pressing in at all.
Natural body oil, dirt, etc. from your finger will sometimes get gunked up under the trackball and cause this problem. Take it to a local authorized Verizon service dealer for cleaning or you can do it yourself which is what I've learned to do. The silver ring around the trackball has to GENTLY be pried off, GENTLY clean the area where the trackball sits as well as the trackball itself with a q-tip moistened with alcohol, allow to dry for approx 45 secs, replace trackball and silver ring. Works for me!
Apr 23, 2010 | RIM BlackBerry 7290
Trackball not functioning
if ur trackball doesnt work because its dirty theres a perfect way to clean it. my trackball get dirty all the time from greay hands and once that trackball starts to feel buttery and greasy its not going to work (usually a htc snap trackball feels rough and vibratety when you scroll with it). I'm not sure if htc trackballs come out so it sort of scratch the trackball with my fingernail, this scratches the grease of until if feels rough again. if the trackball moves around to much when you clean it, press it in with the other fingernail. if this doesnt work i guess you could get some rubbing alcholon a cotton ear bud (q-tip) and clean it but i havent tried this. if a greast trackball is the not the problem to your malfunctioning then i guess you should get a new trackball or get it repaired in a shop. :D
Feb 26, 2010 | HTC Snap S522 Cell Phone
Trackball 8800 Blackberry
Your trackball needs to be cleaned. You have two options.
1) You can send it in to be repaired, or
2) You can clean the trackball yourself.
To clean the trackball yourself:
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! (Like you should be during the whole process as all parts have very small plastic nipple which can break very easy.)
When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position.
The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from.
Once this is done put everything back together to the place each pieces came from and secure the trackball with the silver plastic ring that you removed in the first step.
Your BlackBerry’s trackball should be back working now.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | AT&T Blackberry Curve 8300 Smartphone
My BB Pearl 8100 tracj ball will not select when I
The trackball dome and/or module is bad. Try www.bbmedic.com
Dec 12, 2009 | RIM BlackBerry Pearl 8100
you need to have the trackball either replaced or service
Jul 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
My blackberry world edition's trackball suddenly started selecting things as if I pressed the trackball even though I haven't. If I open email it clicks the links in it as I scroll past and reply pops up...
You might have one of three things wrong with your blackberry 1. something is stuck down there like a peice of plastic causing the button to seem like its being pressed all the time or 2. there could be water damage in there thats if you bring your phone into the bathroom with you while taking showers humidity is like cancer to phones it might not show up right away but it can happen 3. someone might of pushed the trackball so hard that it dented the button in this case i would take it in to get repaired. If it is one of the other two it should be an easy fix you can check for either one of these problems underneath the trackball by removing the ring that is around the trackball you can do this by carefully prying around it off then you should be able to drop the trackball itself right out of the phone aswell as any thing stuck in there or if there is water damage or any water down there I suggest you turn the phone off as soon as possible to prevent any further damage then I would just leave the phone in a nice dry place to get rid of the water then the trackball should work again same thing goes for removing anything that might be stuck down there after that is all done with you should be able to reassemble it remember the ring around the trackball only goes in one way so do force it or you risk breaking it.
Cheers,
Kyle
Jul 05, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Bought used sim card for Blackberry rim 7520
the phone number should be retrieved from the sim card or carrier login procedure.
I had a few blackberry's, including a 75xx series one, and when I popped in another card (I have a couple of prepaid subscriptions for testing), the number always came up automatically.
Should work... If not, try contacting RIM/Blackberry support, but I doubt they'll still give support for the 7xxx series models... sorry
Nov 13, 2008 | RIM BlackBerry 7520 Handheld
Blackberry Trackball
I know this is a bit wierd but it has worked for me. Just lick it a few times.
Nov 24, 2007 | AT&T Blackberry Curve 8300 Smartphone
Cell Phones Logo
69 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
