Copies from original are oriented to top, lose part of material.
I communicated with your support section about my brand new all in one printer. It prints fine from the computer to the printer but when it copies, the copy is not oriented correctly. It is always 3 to 4 spaces to the top. Some documents lose part of the original copy material. I have communicated once and was given two solutions to my problem. One was to Power cycle the product and the other was to Reset the product. None worked and am requesting further assistance. My printer model is C4680 All-In-One Printer. Bought in Oct 2009
    Genius:
  • 1,011 Answers
Sorry, but I need your help here.
What support group are you speaking of?
What is the make and model of your printer?
I'll take a shot in the dark here and recommend that you check to see if you can set the unit to "Scale to Fit Page'.
Also, make sure that the printer does not have a "No Print Zone" around the perimeter of the page. This would force an imposed hard boundary on the page.
One other thing you can try is to reverse the document on the glass. Place the top of the document toward the opposite side that it is pointing to now.
Don
Posted on Nov 19, 2009
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
The machine keeps changing the orientation when you place the papers to be copied on the glass. how can you pick the one you want?
enter additional function(*); on screen, select copy settings>auto orientation> off>ok.
switch off the machine and re start.
place original according to the orientation of paper in paper tray and make copies.
Feb 08, 2011 | Canon ImageRUNNER 3235 Black and White...
Anyone a Canon 5180 i imagerunner expert? Trying to do booklets but the page is coming out with all pages doublesided on one sheet. Help T
Assuming you have a saddle finisher?
Ensure the originals are programmed in correctly.
Highlight booklet on display. Select original size.
Orientation of paper in cassette needs to be A4R.
Program asks if you want stapling.
If no saddle finisher then ensure paper cassettte is A4R.
2 sided, reduce to 2 copies per page,
Sep 25, 2010 | Canon imageRUNNER C3200 Copier
Color copies seem washed out, losing the formerly vivid color...
the printer need maintenance.
go to the following link and download the users manual and select the maintenance section.
May 06, 2009 | Dell 3100cn Laser Printer
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
96 people viewed this question
jasbo
jasbo
