Question about Canon NP 6050 Copier
Black streaks on the copies in the same place every time.
    Problem Solver:
  • 17 Answers
Does it happen when placed on the glass and also through the document feeder? (for optical check)
Inspect the heat rollers to see if they are cut?
Inspect the drum or (photoconductor) for lines.
Optical problems are normally just a cleaning. The other two require parts.
Posted on Nov 21, 2009
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
What is causing black streak
Usually black streaks are caused by faulty rollers in the fuser assy. Depending on how many prints/copies you have on your current one it may be time to change it.
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Fax copy is streaky, almost banded looking. Copies the same too, streaky looking. Toner seems to be full, drum was replaced about 10 months ago with an after market one.
If they are black streaks and they are always in the exact same place, open the cover and clean the skinny little scanning glass. It might be ink or lint. If it's white streaks then it's in the same place but it's dried correction tape or fluid, etc.
Apr 27, 2010 | Brother IntelliFAX 2800 Laser Fax
Black streaks on copies
Sounds like the drum unit has some scarring on the surface and it is causing toner to be picked up in the grooves and placed on to every single page that is printed on the printer.
Pull the drum unit out of the copier and inspect the surface, being careful not to touch it as the oils of your skin will damage the drum surface. If you have scarring around the green/blue/black drum surface then you need to prder a new drum unit.
Hope this helps,
Cheers,
Keith
Jan 13, 2010 | Office Equipment & Supplies
My color copies have a black streak on the front and back of each copy. What can I do.
i have an lexmark 6500 all in one copier. If I print from the computer the copies are o.k., however, if I print a copy from the copier the copies have a black streak on them. How do I get rid of the streak on my copies
Nov 11, 2009 | Epson Aculaser C1100 Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon NP 6050 Copier Logo
109 people viewed this question
old marine
old marine
