Question about ASUS Z71 (90-N9Q1G1000) (90N9Q1G1000) CD-RW/DVD-ROM (Combo) Burner
I need a diagam to fix the front differential on a 94 chevy z71
    Brigadier General:
  • 10,406 Answers
You posted to the "Z71 (90-N9Q1G1000) (90N9Q1G1000) CD-ROM" category. Check 'www.asus.com' for information about the ASUS Z71 CD/DVD drives.
Posted on Nov 19, 2009
On a 99 chevy z71 the four wheel drive selector buttons lights are on all of them . this affects the transmission shifting. What is the problem?
Best to have the codes read. The only way the T case would affect shifting is if it were locked in 4 wheel low. It would shift fast and not gain much speed. Most times it is the encoder motor on the T case that dies.
Dec 26, 2016 | Chevrolet Cars & Trucks
Differential whine?
4x4? Check driveshaft and differentials
Aug 14, 2016 | 2006 Chevrolet Chevrolet Avalanche 1500...
1998 chevy siverado Z71 4x4 noise from front differential when in 2 hi, no noise in 4 hi or low. Changed gear lube lube, went for drive no noise. Next day noise came back, any help
Are you sure that the noise isn't coming from the transfer case? The front dif shouldn't care what gear your transfer case is in, it is either receiving power or it isn't.
Jan 23, 2016 | Cars & Trucks
I have a knocking noise in my front end whenever I put my 1998 gmc sierra z71 in 4 wheel drive
when was the last time you've checked the fluid level in the front differential?
Try this, quickly. these gears don't last long when the fluid level is low, and it's a real big job to replace the gears/differential housing.
I hope this helps, ask if you need anything.
Jan 10, 2011 | 1998 GMC Sierra
4wd won't engage on a 94 Chevy K1500
If you haven't got 12volts at the actuator(TLA) plug, then you are probably correct from what I have researched as well.
I have found a solution to the problem that would eliminate the need for 12volt power or a TLA.
http://www.4x4posi-lok.com/app_chevy-k.html
I keep blowing fuses on my 1997 GMC K1500 and think this switch may be the culprit for me as well.
Jan 02, 2010 | 1994 Chevrolet K1500
I drove my 1994 z71 truck through a creek and now 4x4 doesn't wrk
On the full size, the front actuator is electric, not vacuum.
When in 4wd mode, a switch on top of the transfer case conducts 12 volts out to the actuator. Wire #50 (brown) is the 12v feed, and it conducts to the light blue wire (#900) to the actuator.
When shifted out of 4wd, the switch opens up and no voltage goes to the actuator.
Check voltage at the connector for the front actuator (at the front differential - it looks like a large bullet that threads into the front diff.) If it has 12 volts, the actuator is the problem. If it does not have 12 volts, check the transfer case switch and the power feed to the transfer case.
I'll assume it is the actuator, if the plug to the actuator is getting 12 volts when in 4wd.
The way this actuator works, is it is a sealed chamber that gets heated by voltage. When it heats, the pin in the end swells and pushes a shift fork in the front differential. The shift fork engages a spline on the passenger side of the differential, and boom! you have 4WD.
GM offered an upgrade to this actuator that is a motor instead of a heated device. However, it requires a small harness addition, a spacer, and a new actuator. It is about a $150 to $200 option.
If I were you, I would buy a new heated actuator. They are available at most auto parts stores, and are about $90. They are also on eBay for about $55 plus shipping. These are very easy to change - just thread out the old one, and thread in a new one.
Good luck, That actuator is usually the problem 90% of time.
Dec 02, 2009 | 1994 Chevrolet K2500
Front Differential Noise
Did you ever change a fluid in your front and rear differential?
Mar 21, 2009 | 2001 Chevrolet Suburban
Transfer case chevy truck
a np241 from a th400/4l80e would have the 32 spline that is need for a manual trans, one from a 700r4/4l60e is 27 spline input, in 94 the switch was changed and the cam to activate the switch was changed so if you get a 94 np241 you then will need to wire in a 94 switch into the older harness
Feb 24, 2009 | 1991 Chevrolet K1500
What weight gear oil do i need 99 chevy Z71
I believe that it is 80w90 but you also have to add differential additive for locker that is inside. you can purchase additive at chevy dealership, napa, or other parts stores just make sure it is formulated for gm.
Dec 22, 2008 | 1999 Chevrolet Silverado 1500
4wd
check dealer for update on parts change, solenoind my not be engaging far enough in differential
Nov 26, 2008 | 1999 Chevrolet Silverado 1500
Computers & Internet Logo
172 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
