Question about Acer Aspire SA80 (ASA80UC4603) PC Desktop
On/off button appears on, but nothing happening? I hear fan, but cannot get anything on screen?
    Sergeant:
  • 275 Answers
Have you tried another monitor? This could start your process of elimination.
Posted on Nov 19, 2009
Laptop will not start up
Try holding power button down for 10-15 seconds
Mar 02, 2015 | Computers & Internet
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
Nothing appear on screen. But the power button is lighting on and i can hear the fan at the back of the laptop. i tried removing the battery and tried again but still nothing appear on screen.
If the Hard drive LED is active and it appears that the computer is going through the boot up process then your screen if faulty, probably due to a faulty backlight controller. Try shining a small torch near the screen and see if you can make out any details on the screen. If so then the backlight needs to be repaired.
Feb 24, 2011 | HEWLETT-PACKARD PAVILION DV6870US LAPTOP...
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
When I press the power button to turn the computer on, nothing is displayed on the LCD screen. Power light, Hard Drive light, and Battery Light all appear normally. I hear the fan blowing internally and...
Check the resolution of the screen by right clicking on an empty part of the screen and choosing properties. Go to settings and make the resolution 1078 x 768 and hit apply and ok. There are instances when the resolution will change from a software update etc. that is not supported by the monitor or graphics card.
Sep 03, 2009 | Dell Inspiron 1525 Laptop
My ipod touch screen is blank i can not see my ads on the screen..at first i heard music because i was using while this happen now you can not hear nothing or do anything to it..help it the fisrt time it...
i would suggest reseting it hold the power and the home button at the same time for at least 10 sec or until the ipod resets you should then see an apple logo. reseting your ipod touch will not erase anything.
Jul 27, 2009 | Apple iPod touch
Acer aspire blue screen appeared went off now laptop starts up for few seconds then turns off again, but always a black screen hear the fan a few seconds but nothing
Try this:
  • check to make sure the fan is actually spinning and that there is no debri (dust bunnies) causing it to overheat.
  • Make sure there is nothing preventing airflow, you may need to tilt the back up to allow more airflow
Is there any display at all? Do you see a BIOS splash screen? Do you hear a beep shortly after powering on?
--if you have a splash screen, go into BIOS setup by pressing a button (del,F1,F10...whatever) then set it factory defaults and save changes
--also try removing anything that's detachable (USB, cards, dvd-rom, RAM, Battery...) Hold down the power button for 20 secs then plug in only the A/C and see if you get a bios screen
Hope this helps
Jun 10, 2009 | Acer Aspire 5100 Notebook
Computer display
Could you give us more details, please? Does the PC starts and what happening after you press the power button? Can you hear the fan works? When the problem started and what was changed before the problem occoured? Have you checked the conection between PC and the monitor itself?
Oct 22, 2007 | Computers & Internet
Acer Aspire SA80 (ASA80UC4603) PC Desktop Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
