Question about Insignia IS-LCDTV32 32 in. Television
Insignia lcd tv
Hi
I got a problem in my insignia LCD 32" tv, the picture has a large scale of white, I have tried many things to resolve it but didn't work
  • 6 more comments
  • em_jay Jan 11, 2008
    Here is a sample
    I put a sample picture,
    no it's not too bright
    I have tried all the above, but didn't work! I called Insignia and they suggested BestBuy, and the Tech-support will charge $ 100.00 to just come over and check it out.
    OK
    the caption is off, I will try to check the manual, thanks
    yes
    I have tried to check composite 2 and 3, same problem!
    The other TV is working perfect, so I think the problem with the TV not the Cable.
    OK, thank you
    Sergeant:
    Champion:
  • 347 Answers
Hi em jay,
What do you mean? Your TV is too bright?
Posted on Jan 11, 2008
  • 3 more comments
  • Santiago Vallejo
    Santiago Vallejo Jan 11, 2008
    ah,.
    Did you already cheked your TV options. I mean go to the TV options and make sure anything such as brightness or contrast in in 100 or 0, try to balance them all in 50.
    If they are balanced, you can try to go to the setup menu and select the “Factory Default” option.
    If that dosent work try to leave your TV unplugged for 10 minutes and plug it back,
    If your problem continues then you have a problem with the TV sistem. The 3D digital comb filter can be damaged. If after doing what i told you above you still have the problem call insignia and ask for your warranty. If you dont have it you can try to open it up and replace the compi filter, or call a tech to go to your house and have it fixed.
  • Santiago Vallejo
    Jay you can also try before reseting your TV to factory default, to press the Close Caption in your remote (CC) and make sure that option is turned off,
    For mroe information you can visit this link to your manual if you dont have it.
    http://ec1.images-amazon.com/media/i3d/0...
  • Santiago Vallejo
    If the caption is off and the problem continues, there is another thing we can do to make sure the TV is not damaged. It could be some mistake with your antenna or your cable supplier.
    Have you checked all channels or with a DVD?
  • Santiago Vallejo
    ah, then im afraid to tell you you will either have to open up your TV or call insignia and ask for tech-support or your warranty.
  • Santiago Vallejo
    No problem em jay
We received a second hand 32" insignia about 2
The display panel is bad and to expensive to fix. You can check the board at the top . This is the T con board . Be sure that the flat cables ans pluggin good.
Mar 21, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
I have a 32 inch flat panel lcd tv the picture is too large how do you make it smaller?
On the bottom of the remote (mine anyway) there should be a button that says zoom, you can scroll through settings, wide seems to be the best
Apr 14, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Picture loss
Hi Joe
has the problem been resolved, I am experiencing the same thing, guarantee is 3 weeks out of date -typical!!
Jan 16, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
No signal from coax input on 32" lcd
Hi
Thanks for using FixYa. Due to two things that will cause the No Signal message to come up are – no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No Signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the No Signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 16, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
Sep 30, 2009 | Insignia IS-LCDTV32 32 in. Television
Hi i have insignia lcd 32' but lcd brocken i need to remplaced
buy a new tv. the lcdpanel costs more to replace than you paid for the tv.
Jan 23, 2009 | Insignia IS-LCDTV32 32 in. Television
32'' Insignia LCD is flashin colrs. wh,blk,rd,grn,blu. audio wrks
Very well could be the circuit board. What you describe is VERY common in newer tv's. The company says this supposedly this will be fixed in the new firmware they claim will be sent out soon. The only way you shouldn't experience it, is if I hook nothing to the HDMI input.
My solution is: You have entered a diagnostic color test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button.
Jan 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Set up menu
Hi - if you have this hooked up to a TV cable HD box, you have to make sure you hit "TV" on the cable box remote in order to set up the TV menu. I had to figure this out also with my Insignia 32" LCD TV.
Feb 11, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
247 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
