Question about Eliminator MotoMaster Mobile Power Inverter 700w
I have a 1750w power inverter for my van. The problem is I have absolutely no installation instructions, product manual or line drawingon how to install this product. can you help
  • 66 Answers
Without seeing it its a little tuff.
Ok,look at the back side of the inverter,there should be two inputs.One negative- and one postive+.Run the biggest wire you can get to fit in the holes and still lock it down tight,probaly about six gauge wire.
On the hot side +,run the red wire to the battery,but before you connect to the battery,attach a line fuse,Thirty amp should do.Leave fuse out till last step.Run a black six gauge wire to the battery.(You should be able to run the wires through one of the factory rubber grommets on your van,use a stiff wire, or something like a car or cb antenna to attach your wire to the antenna with electrical tape.you may need to cut a **** in the grommet ,so you can push the antenna threw.Be careful not to damage any factory harness wires.)
Secure the inverter to floor of van,make sure the fan can vent well.
Go to battery put in your thirty amp fuse,Then the unit is ready to turn on.Make sure you run your engine while it is powered on,otherwise it wont take long to drain your battery.
Posted on Nov 20, 2009
Testimonial: "Thanks for the help. I was also told for a 1750 watt that I should have 2 deep cylce batteries as well is this true?"
  • fisherman816
    fisherman816 Nov 20, 2009
    That would be good to have a bigger battery bank,IF you need it.
    It depends on how many things you are going to be powering up off your inverter. This also affects the size of the in line fuse to the battery. The more things you run off your inverter,the more amps you use from the battery. the chart on this page should help you determine your fuse size and if you need more than one battery.
    http://www.macandchris.com/ElectricalSys...
I have a 24' travelaire 1989 rv. is there a switch to go from electrical hook up to battery operated lights in the camper
there is a power inverter,somewhere near the front of the trailer, RV Basics 12 Volt DC Systems
http://www.winnebagoind.com/resources/manuals/pdfs/Winnebago_Catalog.pdf
Atwood Mobile Products: 574-264-2131
Carefree of Colorado: 800-621-2617
Carriage Carpets (Shaw Flooring): 877-706-3054
CCI Controls: 800-521-5228
Coleman: 316-832-4357
Denso: call Fleetwood 800-322-8216
Dometic: 800-544-4881
Fantastic Vent: 800-521-0298
Generac: 888-GENERAC
Intellitec: 800-251-2408
Kidde Safety Products: 800-880-6788
Kwikee Products: 800-736-9961
Magic Chef 800-688-1120
Magnadyne: 800-638-3600
Norcold 800-543-1219
Onan: 800-888-6626
Power Gear: 800-334-471
Riverpark: 800-442-7717
Suburban: 423-775-2131
Suburban Dynatrail Furnace Manuals
Thetford: 800-521-3032
Velvac: 800-783-8871
Winegard: 800-288-8094
Xantrex (invertor/chargers and control panels )
http://www.rverscorner.com/wiring/index.html
Manuals 1989 older RVing The Midwest Connection
May 14, 2015 | Camper Vehicle Parts & Accessories
Need a step by step manual on how too install Transmission Shifting Solenoid on a 2001 Chevorlet Venture Van LS let
Suggest purchasing a Haynes manual which will have the step by step instructions. It is too complicated to post on FixYa. Alternatively you can sign up for a free account at Autozone and they have some manuals available online for free. They are not as good as a Haynes manual.
Mar 26, 2013 | Cars & Trucks
Coil is bad in my hw2000i
Go on line to the Honeywell website and check out users manuals. They probably have a download you can get!
Dec 26, 2012 | Honeywell 2000 Watt Inverter Generator...
Lost operation instruction and a hooch up line #2354
http://www.batterystuff.com/manuals/manual-IPD-1800.pdf go to the website presented and down load the manual, make sure you have PDF application installed so you can read the information.
Mar 06, 2012 | Electronics - Others
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Oct 24, 2010 | Eliminator MotoMaster Mobile Power...
I need a lithona lighting power sentry psdl3 wiring diagram
http://www.lithonia.com/SpecSheets.aspx
Lithona has a lot of products and they show the manuals.
Unlike a lot of companies where manuals are not available, as if customers live in the 1980's and still write to companies asking for information.
I don't see your speicific product at Lithona.
A search for 'power sentry' turned up many possible products.
Unlike a lot of sites that just say, 0 results.
Many times, the same product will have more than 1 name or product-number depending on who is selling the product >>> that's how different companies can sell the same product but claim their product line is unique.
You might search the manuals at Lithona and find a similar product under a different name or number.
Oct 15, 2010 | Lithonia Lighting Psq500 Power Sentry...
I have 1750w mobile power inverter turn on light comes on then the falt light come on right away.
Like most Cheap square wave inverters, the mosfets can not take the inrush current.
Usually if the fault light comes on and there is NO voltage at the output, FIRST check the on board fuse, then check for any tell-tale burn spots, or areas where the components have heated up or burned.....if you get this far and all appears clear, then it is time to check the fets.
I would not reccomend any Motomaster Eliminator inverter other than the more costly sine wave unit....or stay with a 1kw unit and do not overload it.
It\s best to run as much as you can at 12vdc or higher...like 24vds. AC is nothing but problems.
Apr 10, 2010 | Eliminator MotoMaster Mobile Power...
Hi; I have a 1750w eliminator but no fitting instuctions. is it just a case of fitting it straight to the battery . is it as simple as that ? what if the truck has 4 batteries how do i know which to...
Sounds like your a truck driver. Anyways you would hook up the ground to the negative and the hot to the positive side. The 4 batteries are in a series so just pick a negative and positive. I hope this has helped, please give a rating on the answer. Good Luck and have a great weekend.
Apr 02, 2010 | Eliminator MotoMaster Mobile Power...
DTV Conversion Question
Yes you can connect a DTV converter box in your van.
If the TV is DC powered you will need to buy a DC to AC inverter, like these http://www.dcacpowerinverters.com/12_volt_power_inverters.html because there are currently no dc dtv converters available.
If the tv is ac powered you will only need to connect the converter to the inverter the tv is connected to.
If you need more help or installation instructions let me know.
Please rate this solution.
Lone99star
Apr 03, 2009 | RCA R52WH73 Projection Television
Eliminator MotoMaster Mobile Power Inverter 700w Logo
1,670 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Mark Magill
Mark Magill
Tom Chichester
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
