Question about Kenmore 73952 Gas Dryer
Sounds like it is scraping when turned on
Makes a very loud screach when it runs, almost sounds like it gonna blow up
  • rjhahn May 11, 2010
    Your bearing that is on the end of the drum.
    Sergeant:
  • 222 Answers
You've got some worn out friction pads, rollers, or bearings. Do not run the dryer in this condition... It will damage the drum (if it hasn't already).
You'll need to remove the front to look at the front drum supports and the rear support rollers. Once you are able to see inside the dryer, it should be pretty obvious which parts are defective.
Posted on Nov 23, 2009
2000 Subaru Impreza Sedan; Couple different noises
the screaching noise is 1 of your belts needs to be tightened. noise from the right front tire sounds like a bad sturt or ball joint and that needs to looked at
Jan 07, 2013 | 2000 Subaru Impreza
Dryer makes screaching and scraping sound while running with clothes in it
It could possibly have a bad bearing on one of the rollers that carry the tumbler drum and with the weight of the wet clothes it will probably be worse than when dry. It is probably rubbing some where. Unhook the power and pull the back cover and look around carefully. Lift the weight off of the drum and check drum rollers.
Aug 31, 2011 | GE Dryers
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 | Dryers
Tv is making a loud screaching noise and no pic or
Ur high voltage flyback transformer it dead.
U need a new one.
Aug 20, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Need blower wheel replaCDED?
If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
May 07, 2009 | Maytag PYE2300AY Electric Dryer
Acheiver CCS5000 screaching noise
A piece of metal or coin might have gone into the shredder.
Apr 22, 2009 | Achiever CCS5000 Shredder
Loud niose from centre of manafold motor run nice & smooth ?
on the 302 you can not see the cam and lifters unless you remove the manifold. did you try removing the distributer and turning the oil pump shaft until the light in the dash goes out? that will drive oil to the upper cylinder assemblies, other than that you may be looking at replaceing some damaged bearings and or camshaft.
Apr 03, 2009 | 1978 Ford Granada
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Kenmore 73952 Gas Dryer Logo
65 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
