Question about Kenmore Washing Machines
Drains wont' spin,or agitate - Kenmore Washing Machines
  • rjhahn May 11, 2010
    Timer is hanging up.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Nov 19, 2009
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Wont spin, drain or agitate
the transmission is either burnt out or the freaky looking belt that turns the pump is off. or the switch that tells the unit that the top lid is down sometimes comes loose cause some companies used a caulk like substance to keep the foot attached to the switch as slid away from where it is and the lid is not pressing that foot down to close the circuit and tell the tranny its safe to spin etc. You can fill with the lid open but not spin. There is a motor that controls all the spinning and draining or agitation and if something in their design is opening the circuit it wont perform those functions.
another idea is the timer motor isn't making contact and you might have to replace that..... there are tons of issues that can cause that.
Feb 20, 2014 | Amana Washing Machines
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Wont agitate,but does spin/drain
you have worn out dog agitation ears. it's a very easy fix. parts should be no more than $10. Good luck :) please let me know if you need any other help.
Jul 07, 2009 | GE WVSR1060A Top Load Washer
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
