Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker has stopped working and filter indicator says "change" Could they be related? How do I change the filter?
    Sergeant:
    Champion:
  • 289 Answers
Open frig door and look down and to the left on kick plate and you will see the filter.
Posted on Nov 19, 2009
We changed the filter for the water, now it will not dispense water, but the ice maker still works.
Hello nott225 - The issue sounds like it might be related to the temperature in the freezer. What is it set to? Make sure that the temperature is approximately around 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If it is properly set, then consult a professional to accurately pinpoint any potentially more serious issues like a faulty ice maker valve or even the ice maker itself.
Feb 03, 2013 | Frigidaire FRS23H7CS Side by Side...
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
The water dispenser is really slow coming out and it takes however to make ice. There is no kink in the water line to the fridge.
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
Dec 26, 2010 | LG LRSC-26922 Side by Side Refrigerator
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Purchased a water filter for my estate refrigator and the ice maker stop working.
when you replaced the filter did you check the flow before installing. I have had filters actually clogged right out of the package. Also most filters have a flow direction indicated with an arrow on the filter
Apr 15, 2009 | Refrigerators
Ice Maker Problem Question
take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
May 22, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not working
Just a guess...the filter was installed wrong or there is foreign material in the seating area inside. Get that flashlight out.
Nov 02, 2007 | Maytag MZD2766GES Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
89 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
