Question about HP LaserJet 3055 All-In-One Printer
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
    Scholar:
  • 83 Answers
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Posted on Nov 19, 2009
Testimonial: "thank you for your time. Very helpful"
How do I scan into a PDF with MX922
Making an adjust to the IJ Scan Utility settings should fix this problem. Follow these steps:
  1. Open the IJ Scan Utility.
  2. Click the Settings... button in the bottom right of the window.
  3. Highlight Document Scan, to view the document scan settings.
  4. In the Save Settings section, change the Data Format to PDF (Multiple Pages) and click OK
  5. Back at the IJ Scan Utility window, load your documents in the ADF and click the Document button to start your scan.
Feb 19, 2015 | Canon Office Equipment & Supplies
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
    Please clarify a few things for me so I can help you solve this issue.
    Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
    OR
    Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
    If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
    There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
    To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
    Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
    Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Internal DRS error when scanning
    When you go to do the scan using the "HP Solutions Centre" "Scan Document" button (press this now).
    Click on the "Change Settings" button (lower right side of scan window) in the window that opens. This opens the "Scan Document Button" window. Make sure the "Show a preview scan." box is ticked (In Button settings bottom right of window.
    Click on the "Advanced Document Settings..." button (Right Hand side 2nd under "Scan Type)
    Change the "Output Resolution (ppi) for Document as Image:" to 200. While here, check the correct language is selected. I also tried an Output Resolution of 600ppi. This seemed to make no difference as the system defaults back to 300ppi when the scan is carried out, regardless of what has been selected, but still scans as expected instead of erroring. For some reason I have yet to discover, simply changing the ppi removes the erroring!!
    While here (in the "Advanced Document Settings..."), now would be a good time to change the scan to "Black & White" which in itself reduced my scan from 24.5MB to 1MB The only thing you'll need to do then is, after the scan, adjust the "Black and White" level manually for clearest picture. I got the best results this way. If you forget to select this at this point, don't worry, it can be done from the next window (HP Scanning)
    Now click the "OK" button. This takes you back to the "Scanning from... Scan Document button (HP Solution Centre) window. Now click on the "Scan" button (in the "Scanning from...Scan Document Button (HP Solution Centre)" window.
    Now you'll be in the "HP Scanning" window which is where you can make any final changes you deem neccessary. You can also see how big your file is and how each change makes a difference to the size of your file. Note that this is not the storage size. It is the size of the "working in ram" file.
    When the document is the way you want it, then select finish. This time, it should go through to the final program as expected. Don't expect every character to be correctly recognised, especially with any hand written documents. Tables are especially notoriusly bad.
    Hope this helps. Good luck and I'll let you know if I find anything else to help.
    When it works, it works well. In the mean time......
    May 28, 2010 | HP Officejet J5780 All-In-One InkJet...
    Which is the scan button mp520 canon printer
    Easy Scanning with One-click You can complete from scanning to saving easily by simply clicking the corresponding icon.
    1. Place the document face-down on the platen.
    2. On the Windows desktop, double-click (MP Navigator EX 1.0).
    Alternatively, on the Windows taskbar, click Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.
    The MP Navigator EX navigation mode screen or one-click mode screen opens.
    3. Point to One-click.
    4. Click the corresponding icon.
    Save to PC
    Scan documents or photographs and save them to a computer.
    The Save dialog box opens when you click this button. Specify the scan/save settings and scan.
    Save as PDF file
    Scan documents, save them as PDF files and start the specified application.
    The PDF dialog box opens when you click this button. Specify the scan/save settings and scan.
    Attach to E-mail
    Scan documents or photographs and attach them to e-mail.
    The Mail dialog box opens when you click this button. Specify the save settings and e-mail software program, and scan.
    OCR
    Scan text documents and open them in OmniPage SE by default.
    The OCR dialog box opens when you click this button. Specify the save settings and application, and scan.
    May 18, 2010 | Canon MP520 All-In-One InkJet Photo...
    I want to scan my document and send to my shared documents what can i do?
    There are many ways to scan .. using different software.
    Since you have'nt mentioned the kind of pc u have and the operating system.
    Try this...
    Click the Start button , click All Programs , click Accessories , and then click Paint .
    In Paint Click File , and then click Import From Camera or Scanner .
    Make any desired setting changes, and then click Scan .
    Now you can save the scanned document in your shared folder.. by clicking on Save As
    Hope it works
    All the best !!!
    May 06, 2010 | HP DeskJet F380 All-In-One Printer
    How do I scan a picture from my HP (Printer*Scanner*Copier on to my PC
    To scan a picture follow the following steps :
    1. Click on start then click on All program
    2. Click on the HP , and then click on HP Solution Center 3. If you want to scan a photo then Click the on-screen Scan Picture "button" in HP Solution Center.
    If you want to scan a document without document then Click the on-screen Scan Document "button" in HP Solution Center.
    4. Set the option to prompt for settings each time you scan, and then click OK
    5. At last click on Scan.
    and save your file.
    Regards
    Ashly
    Feb 25, 2010 | HP Photosmart C4180 All-In-One InkJet...
    Scan to pc not working in wifi
    I'm not using WiFi, but the principle is the same if the issue is "PC Not Available" when you press the "Scan to PC" button, with USB, Ethernet, or WiFi connected printers.
    Left click on the up arrow at the right hand side of the tool bar by the clock to show the "Hidden Icons." Right click on the icon for the Samsung printer, and select the
    The scan to pc needs the path set properly. In my case, it was to "My Documents," but the "Scan and Fax Manager."
    Click on the center top option for "Set Scan Button." Look at the right hand box for the destination listed. Mine was "My Documents."
    Now look down half way in the window to the left for "Scan Property." Note the "Save Location" that is listed. In my case it was "My Scans," which is a sub folder of "My Documents" but the printer could not connetect to the sub folder. So, I clicked on the yellow folder to the right to select a different path. On the pop up window, click on its yellow folder and select the "My Documents" folder under the proper user's name, and then click okay. The path should now read c:\User\<username here>\Documents. Click okay.
    Now when you press the Scan to PC button, it can find the path to the standard windows folder and not give the error of "PC Not Available."
    The troubleshooting guide said to simply check the port. LOL. I'll work on seeing if I can get a sub folder to work later, but for now it's working okay. Hope this helps someone.
    Craig
    Oct 05, 2009 | Samsung SCX-4500 Laser Printer
    Hp 2210 allinone
    I just went through this with HP tech. Seems this is an known problem and their solution is for you to purchase a refurbished or new printer from them which happens to be more than you can purchase online.
    You can try taking a lint free cloth, popping out your cartridges and briskly rubbing the copper and ink nozzle part of the cartridges to see if that works. Also briskly rub the connections inside the printer itself where the cartirdges make contact. If this doesn't work then you now have a HP paperweight.
    I haven't had any luck with HP printers. Always something goofy going wrong. Software gets corrupt, update can't update, won't print, etc... I purchased this thing new and had to return it the first week for a replacement because it wouldn't power on.
    I'm going to another brand. Possibly Cannon or Epson and hope for the best. Anyway good luck!
    Aug 22, 2008 | HP Officejet 5610 All-In-One InkJet...
    Can't scan
    This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
    Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
    HP LaserJet 3055 All-In-One Printer Logo
    347 people viewed this question
    Seeker5211
    Seeker5211
