Question about Bunn NHB Coffee Maker
The top burner on our bunn coffee maker is getting to hot, causing the coffee to pop, do you have any suggestions on how to fix this problem? Please advise
  • 131 Answers
Bunn makes a spacer that goes on top of the burner to put space between the burner and the coffee pot, or you can make your own out of a coat hanger. The only other way to fix this is to replace the warmer plate.
Posted on Nov 26, 2009
Bunn coffee maker, no hot water
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Mar 16, 2013 | Bunn CWTF35
I have a 3 burner that I got on ebay and it seems to want to get the water too hot. It gets hot enough that it sends steam from everywhere. I imagine that that is due to water boiling in the tank? I...
Hello, yes you are correct, it's due to the water boiling in the tank. take 2 screws out of the top panel, just under this panel you will find the thermostat (it's ajustable) turn the temp down on the thermostat, if this does not solve the problem your thermostat may be bad and you will have to replace it. You can purchase new parts from either bunn direct or from holiday house in california. if you have any additional questions please feel free to comment again. Good Luck! Mike
Oct 16, 2009 | Bunn VPR Coffee Maker
Warmer gets to hot over heats coffee
Your coil may be shorting out on your warmer.
Try using the upper warmer and see if the same thing happens. If not, a cheap solution is to swap burners and order a new one . If both overheat, you have too much voltage going to your bunn.
Oct 13, 2009 | Bunn VPR Coffee Maker
Bacon grease in my bunn coffee pot
Did you let the vinegar mix with the hot water in the tank for 2 hours? If this didn't fix the problem, please call 800-352-2866 with the model and date code and we will be happy to assist you with this problem.
Mar 29, 2009 | Bunn BCW Coffee Pot and Decanter Warmer
Bunn Coffee Maker Not Working
Tammy,
Plug the coffee maker in and fiIl with water again and let it flow through. Do this several times.
I don't think household bleach would cause any damage to the unit. Industrial bleach, yes, but not household, especially if diluted with water.
Let me know what you find.
Jan 28, 2009 | Bunn NHB Coffee Maker
Bunn VPS 3
Are you leaving the machine plugged in all of the time? If not, you need to. The machine takes approximately 10 minutes to get to full temperature the first time then the water should stay hot from then on. Or it could be that you just need to turn up the thermostat. No, the water won't get hotter sitting on the burner and the coffee won't taste as good if the water you are brewing with isn't hot enough.
To get to the thermostat, unplug the machine and take the two screws on the top lid off. You should see a box that has a knob or a T sticking out of it. Turn it up a little bit, put the lid back on and let the heat up for a little while (10 - 15 minutes). Try brewing with just plain water. If it still isn't hot enough, repeat the steps above. Make sure you don't turn up the thermostat so much that the water boils.
Nov 06, 2008 | Bunn VPS Coffee Maker
Water not dispensing with ITCB-DV series Bunn Tea Brewer
the tank is not full. the sensor at the top is being bridged and it thinks it's full. pop it out and clean it and delime the tank.
Apr 12, 2008 | Bunn Tea & Coffee Maker Infusion Series...
Dripping
Is the burner hot when this occurs?
Sep 14, 2007 | Bunn A10 Coffee Maker
Bunn coffee maker
Is the burner hot while your pouring water in?
Sep 14, 2007 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
137 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
