Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working I turned switch on but lite did not come on We hooked up water to refrigerator for the first time and turned on icemaker. water at door works. Model number is GSS20ite WW
  • acekompute Nov 21, 2009
    Not sure. We bought the house and the Frige came with it. Ice maker and water to door had never been hooked up. We hooked up the water line and the water to door worked. Found a switch to ice maker and turned it on but nothing happened. Light on ice maker did not light. Fridge looks like new but believe it is 5 or 6 years old.
    Herb
  • John Tripp
    John Tripp May 11, 2010
    If this was a new ice maker that could happen. But when one sits in freezer and the water was not on and the electronic ice maker could have been left on without you knowing. There are some test points behind the plug in the freezer and on the mother board. Let me know how long the ice maker has been inside freezer and not used. Sea Breeze
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
gfhf
Posted on Sep 30, 2010
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
    If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
    If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
    Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    We recently moved and hooked up the water/ice. It
    Replace the icemaker.
    If the ice maker mold is tan or silver they are defective.
    Moisture gets into the head unit and jams the gears.
    You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
    The new redesigned icemakers are brown in color.
    Hopefully the switch on the side of the I/M is turned on..
    Jan 09, 2010 | LG LRFD25850 French Door Refrigerator
    I hooked up the ice maker and no water goes to the tray .i have lights on at the icemaker,but,the cam that removes the ice cubes dosent seem to be moving.
    There are a couple of possible problems.
    1) Make sure water feed is turned on ALL THE WAY.
    2) Make sure the ice level switch is down, cause when it is up, it stops making ice.
    3) Make sure the solenoid valve that governs water flow to the icemaker is working.
    Jul 29, 2009 | LG Refrigerators
    Ice maker will not work
    is the icemaker on did you turn on the water are you getting water to drink on the door
    Apr 07, 2009 | Kenmore Refrigerators
    Ice maker not turned on or hooked to water line
    it my be not the icemaker check fan or you can remove icemaker
    Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
    try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
    Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
    Subzero 500 series ice maker
    It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
    Oct 18, 2008 | Refrigerators
    Ice maker not getting water in the line
    The only other component stopping the valve from putting water into your icemaker is the icemaker itself. Replace your icemaker and you should solve your problem.
    Nov 14, 2007 | Amana ARS2464B Side by Side Refrigerator
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    109 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Gene Tuck
