Question about Sony Televison & Video
KV32XBR450 no picture and blinking stand By light
I have a kv32xbr450. when I power on I get the stand by light blinking in a series of 4. if I hit power again I get the stand by light then the stero light then back to the stand by light and this time the blinks are in a series of 7
    Sergeant:
  • 309 Answers
Typically, 4 blinks mean "Vertical Deflection Stopped." Chances are that you have a problem on the D board.
Posted on Nov 19, 2009
THE POWER STAND BY LIGHT IS FLASHING RED 4 TIMES
Anything less than 5 blinks is major trouble. More likely vertical IC and circuit failure. Picture has been muted or turned off by TV. If Stand By light was blinking 5 times the Stand By might have came out self-diagnosis function or mode.
Contact Sony Service Tech for service adjustment to fix problem.
Oct 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
Nov 17, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
4 Blinking Lights no screen
Please confirm that the model number is KV-27FS100 and I'll provide the parts and instructions.
Thanks,
Dan
Oct 14, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
No picture but sound on the tv
In regards to the Sony KV32XBR450 without picture but sound, mine just had this problem occur yesterday. After doing a quick troubleshooting check, I have found that the problem is most likely a bad tuner, as when I directly connected a video source to the RF (Cable Coax) connector, I wasn't able to get a picture, etc.
I was able to "by-pass" this issue for now, while I wait for the replacement part (special order via Sony Authorized Repair Service Ctr), by using the S-video output from my Dish Network and plugging that into the S-Vedio input on the back of the TV, (you might also have S-video output on your local cable box too). Now I've got a really nice picture, but without sound, so all you need to do is utilize either your Audio outputs from your Satelite Box or Cable Box and connect them to your Audio inputs under the S-Video cable and you'll have picture and sound. If you have a DVD/VCR, etc. with audio feed-thru connections, you can also accomplish this with your standard hook-ups to that device, just select it for the sound while you use video 3 (or 4) where you connected the S-Video cable.
This will let you contact your local repair/service center and see if they can get the parts needed to make the repair. I figure that the parts will run between $40-$120, plus a $50 diagnostic fee (usually applied towards your repair bill), plus the labor charge. If I was having the repair done by the shop, I'd expect to pay around $200-$250 +/-. Not bad for a HD Flat panel TV when you consider that a new Flat panel with 1/2 the resolution (720p) will cost you $450 +/-
and a 1080i is more than double that. Remember that the Sony KV32XBR450 is HD 1080i and 720p in one unit. Hope this helps.
Jan 05, 2008 | Emerson EWF2004 20" TV
No picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Jun 13, 2007 | Sony KP-51HW40 51" Rear Projection...
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
185 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
