Question about Samsung VR8060 VCR
Safe Mode It says "safe" on the display, how do i get rid of that?It also doesnt play tapes when it displays this.
  • crystalb Jan 21, 2008
    i have a proble with my is vcr rca vr641hf it is safe mode and i dont know who to fix it please help
    thanks crystal
  • Anonymous Jan 22, 2008
    TENDO EL MISMO PROBLEMA CON UN DVD SAMSUNG MODELO DVD-R130, EL DISPLAY INDICA SAFE Y NO SE PUEDE REALIZAR NINGUNA FUNCION.
I just fixed mine...all you do is hold the tv / vcr button on your remote for 30 seconds...
Posted on Jan 28, 2008
Tip
Login into safe mode.
You can use safe mode for a number of things...
Uninstalling programs that refuse to unistall in normal login;
Performing a system restore;
Scanning for dangerous viruses and Trojans;
and so many other things.
How ever, you can not install programs in safe mode because the installer is disabled.
In safe mod, you sound and graphics cards are also disabled, so you cant listen to anything or play video games.
To start your system in safe mode:
1. restart your system.
2. During system restart, press F8 before your Operating System (OS) is loaded, before the OS logo is displayed.
3. A list of options will be displayed, which include "Start Windows Normally","Safe Mode" among other options.
4. Select safe mod and press enter.
5. Give it a few seconds for safe mode to start, then log into your administrator account to start using safe mode.
on Jan 09, 2010 | Computers & Internet
My windows xp desktop keeps on shutting down after some minutes then the screen displays power safe mode. How do I get rid of this? TIA
If it gives you enought time, run cmd: and then execute
CHKDSK C: /F
presuming c: is your system drive, else select
corresponding
Also you might try Systerm Restore to point BERFORE this all happened.
If ask for restart, Restart
May 06, 2015 | Computers & Internet
Can't get rid of the safe mode. Error 04. Know matter what I do
Are you already try changing tapes, if still try to hairdying the mecanism if you use the same tape after first try turn forward your tape manual, usually the cause of error 4 is the drumhead doesnt spinning cause sticky tape,
Hope this solve your problem
Oct 23, 2013 | JVC Cybercam GR-DVM90 Mini DV Digital...
6 hours old computer was working fine the shut down to load windows update then there was no video even unplugging and pressing the power button as aspire website suggested i have power but no video and...
Restart the computer and press "Del"key or F2 key.. check whether any responce on display, if BIOS is displayed , then display is ok.
Then restart the computer and press F8 key continuosly till "SAFE MODE" list displaying. if displayed safe mode list, select "Enable VGA mode". then press enter. try to login to windows. then change the resolution if required.
Jun 09, 2011 | Computers & Internet
I have dell laptop.Cursor is showing. caplock on
No display? but you have an mouse cursor showing? So you must have an display and it is locking on startup of the OS. Do you have an bootable cd? If not lets try to start it up in safe mode..
1: power down system
2: on power up hit the F8 key keep taping it till you get display saying startup in safe mode.
3: start up in safe mode no network.
4: if it starts up to an desktop then its an driver or software which you have installed causing normal startup to stop.
If it doesn't start in safe mode we will have to boot to an OS CD.
Let me know how these first steps go..
Feb 23, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
Input not Supported
The signal being sent is outside of the rated limits of the monitor (vertical or horizontal synch rates). Boot up in safe mode (by hitting F8 during the initial startup of the computer, before the windows logo screen comes up). Select Safe Mode. If you get a display in this mode, then you know your graphics card is sending a signal outside of the monitors limits, if not, then the monitor itself is probably bad. NOTE: The following steps are for Windows XP only... if you have a different OS, please reply and I'll research the steps for you.
If it is your graphics card, while in safe mode, right click on My Computer and choose Properties. Click on the Hardware tab. Click on Device Manager and double click the Display Adapter entry. Right click on your graphics card and click uninstall. This will force the computer to reinstall the graphics drivers at bootup and, hopefully, reset the adapters output mode. Reboot the system and once in, set your display settings to the best for your monitor (Windows XP should pick the best setting if the monitor is plug and play).
Feb 19, 2010 | Acer 22" X223w LCD Monitor
Cant eject, display says safe, cant even get menu
I can help with your locked dvd player.
To get the word SAFE to disappear, follow these steps.
I hope that helps.
Apr 29, 2009 | Califone International DVDVCR200 DVD...
SCREEN SAYS "SAFE" ?DO IDO TO GET RID OF IT???????/
To remove "SAFE" from the front display, using the remote control, press and hold "INFO" for 5 seconds until it disappears. This was probably acitivated while you stopped a recording which can trigger it, of you may have activated "Safe" by pressing the INFO button several times. This is to prevent access of the recorder by locking all controls. This is for the DVD Recorder/VCR combo VR320 and the 1st generation DvD Recorder DVR-130.
Even though this was a product I regret purchasing, it isn't as bad a people make it out to be. It works best with DV cable recording from 1 Hour Mini-DV tape camcorders to 1 Hour XP Record DVD mode. It is probable one of the best. Only issue I have is when you try playing a finalized DVD-R disc in another DVD player, there is a chance it might not work because of the Highest quality 1 Hour record mode. Standard is 2 Hour SP. You will have to burn an exact copy using DVD copy software on your computer to DVD-R. This will fix the problem.
May 31, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Safe!!!
Go inside and REPLACE e v e r y rubber band that u find in machine. Don't replace one or two, if you find one or two bad
REPLACE THEM ALL.
May 23, 2008 | RCA VR355 VHS VCR
Samsung VR8060 VCR Logo
356 people viewed this question
Jerry Greenberg
Jerry Greenberg
