Question about Campbell Hausfeld Air Tools & Compressors
How to rebuild an inline dual action sander - Campbell Hausfeld Air Tools & Compressors
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: my cp 864 dual action sander needs part
You could buy it from :-
http://www.toolsource.com/valve-kf124233-p-74658.html
Click on Add to Cart and then Purchase the Amount.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 17, 2010
How do I install paper to Skil Dual Action Sander model # 7372?
Sander has 2 slotted rotating rollers one on each end the paper gets fed in as you rotate roller, which will grasp paper and hold, feed/wind roller with slotted screwdriver till paper secure. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Skil nbsp7372 TYPE 1 nbspDUAL ACTION SANDER 348542
Jul 28, 2014 | Skil Tools & Hardware - Others
Sander won't shut off
Most likely the throttle valve is stuck open. On sanders usually sanding debris has coated the throttle valve pin, causing it to stick. Other times the throttle valve seal has worn and needs replacement.
Mar 17, 2014 | Ingersoll Rand 311a Air Dual Action Quiet...
What is the maximum weight that the Alps Mounaineering dual action chair can hold?
This chair is awesome due to its size and how sturdy it is. This chair was designed to carry up to 275 lbs and built so you can sit on it for hours on end.
Feb 16, 2014 | ALPS MOUNTAINEERING Dual Action Chair
Craftsman dual action sander model#875.199770. how do you remove sanding pad to replace with new one?
I used a thin vise grip to hold the spindle and the old rubber pad was easily removed.
Apr 17, 2013 | Craftsman Dual Action Sander
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
My cp 864 dual action sander needs part #KF-124233. Is it available?
Hope i helped you.
Mar 17, 2010 | Chicago Pneumatic CP864 Dual Action Air...
DA SANDER RPMS SLOWED
get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
May 23, 2009 | Chicago Pneumatic 864 6" Heavy Duty Dual...
Air Tools & Compressors Logo
161 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
