Question about Mitsubishi VS-6041 60" Rear Projection Television
I hear a click every time I attempt to power up and nothing appears to be turning on. Prior to this, I was noticing some lines near the bottom of the screen that would come and go randomly.
  • 834 Answers
The convergance amps have gone bad you need to have somone replace them alot with the 2 bad resistors that will be burnt
Posted on Nov 19, 2009
Hi!2012 Chrysler Town and Country front wheel drive. Where is the starter. Front, back, side? Is it hard to get to?
Front right as you look down on the engine. Follow the dip stick pipe down to it's bottom, (yellow). It will be to the right of where the pipe enters the engine block, fitted from left to right, (red). See photo.
May 01, 2018 | Chrysler Cars & Trucks
01 durango 5.9 no bus message but if I wiggle the black connector at the pcm the car starts but shuts down after a minute or so,meaning the fuel will not prime without me doing that ,prior to the no b
Remove the black connector to pcm . Check for corrosion pins . Then inspect the plug end for corrosion. I found moisture seep by the weather pack seal and wire on older vehicles.
Feb 11, 2015 | 2001 Dodge Durango
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Comdial Unisyn phones no longer ring in all locations
you can contact me at brcrory@buyrite.com depending on where you are i can service the system or recomend someone
Apr 09, 2010 | Comdial Unisyn 1122S Corded Phone
Won't start but power is fine
Do you hear a clicking sound when ignition is turned on? If you do then you are loosing contact on your starter, or solenoid, if you don't hear a clicking it could be the solenoid, do you hear the fuel pump priming whenyou turn the ignition on. I would start with making sure the wires to the solenoid and the starter are not corroded, if they are you will have to take them loose, scrape and grease them and try again. Hope this helps you man. Another thing, are the timing belts that your friend replaced timed right, or did they need timed? I don't know on that vehicle.
Nov 06, 2009 | 1993 Eagle Talon
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Clicking sound in back of tv when you try to turn it on
Sounds like this could be a dry soldering joint in the TV power circuit. This can easily be repaired with a small soldering iron and soldering wire.
Best wishes,
Graemevm
Jun 06, 2009 | Philips 27PT543S 27" TV
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
