Question about Sony Xplod XM-1652Z Car Audio Amplifier
Sony xm-1652z 1000 watt amp
My amp has been working fine since I put it in my truck 7 months ago then the other day it started cutting out then stopped working now it powers on but when you try to turn it up it blows the 30 amp fuses in the amp. I"m running 5 guage wire and I have a cap and I'm pushing a 1200 watt sony sub I don't know what to do it's driving me crazy if anyone can help me it would be greatly appreciated
Ive also had that problem when the amp wasnt getting enough power as well ... so at low power it would work fine but when you turned the gain up it starved for power and blew the fuses or just cut out off and on
Posted on Jan 18, 2008
A loose or corroded connection can cause this problem...do not overlook possible loose fuse holder...also look into remote control line...also check speaker line for a loose or shorted connection...a loose connection in any of these locations can cause a spike in the current drawn from the power supply... a bad speaker can play at low volume but short at high volume; if the flex wires from frame to cone on the speaker start to fail, it happens at high volume first, and sounds like a crackle, and gradually becomes present at lower levels; a voice coil can warp at high signal levels, causing it to short intermittently, in addition, you might check the cooling capability of the amp...i don't recall whether you have a fan on this amp...
Posted on Jan 11, 2008
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a sony xplod 1652z 1000 watt amp and want to hook up 2 subs and the speakers that are already installed in the truck is that possible?
thats not a good idea because you are running too many speakers off that amp it it could possibly blow a channel or the whole amp. trust me i've done it
Jun 10, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I have 2 1100watt sony xplods will they run off a 1000 watt amp
yes it will work, but it will only put out the power to the sub that the amp allows, ie : 100 watt amp puts out 100 wats.
you can also try reconfigering your wire to your subs, if your amp is 1ohm stable and your subs you can come off the amp with a bridge and run subs in series or parralell, this will dramaticly improve the bass
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a Sony Xplod XM-1652Z 1000 W. I am using it to power my 2 Infinity 10" subs with 1052 watts on each Max. My problem is that when i turn on the volume too high the subs would stop working. My friend...
Sony audio products are not worth the buck, you will be facing worst problems in the future, my advice is just to change the amps. It is causing the problem, it cant handle frequencies when volume is turned up. and it may say 1000 watts but actually this is the peak rating your amp can handle thus meaning that it couldnt handle constant high volume usage, try crunch, kicker or hifonics amp, and look at the RMS rating on the amps when shoping.
Mar 31, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Feb 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000 watt car amp quit working.
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
Feb 03, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
149 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
