Question about Maxtor Hard Drive
Cant windows installation
Some setup files lost of my hitachi deskstar 7k80 HDD
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Files are lost then reinstall if it dont copy the files during installation that means your RAM is having problem loading the files. replace the RAM and then check it.
best of luck
Posted on Jan 16, 2008
HDD Problem
The info is not clear as to if it is a desktop or laptop . However what u could try is reseating the hdd and also get into BIOS by tapping F2 and u would find a option to restore defaults, after restoring check if the hdd is getting detected . Also make sure that external peripheral like Ext hdd and other usb devices are disconnected. Update once u have tried this.
Apr 02, 2010 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
DIY solution for data recovery on a failing Hitachi HDD
Yes it is possible to data recover from this hard disk to using "active partetion recover v2.0 or above" software. This software should be registered and also bootable disk. It will be possible to data recover, if it will be detect in dos mode.
Procedure:
Insert the bootable disk into CD-Rom and choose boot from the cd rom and now check your disk is detected or not, if detected follow the instruction and your all data could be recover with your complete partions.
Good Luck
Dec 14, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
HItachi deskstar Hard disk 80gb 7200 rpm
check the power cord of your hard disk. It should be tight not loose, if not solve then change the power cord.
Nov 25, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
My hard disc purchase date is march, 2006, It is not working can I replace it
Most drives are under warranty for three years from purchase date.
You can check to see if it's under warranty from Hitachi HERE.
Nov 24, 2009 | Hitachi Deskstar® 7K80 80 GB SATA Hard...
Wall mounting hitachi 32ld7200
Should be able to. it's 25kg or 55lb ..
Nov 07, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hitachi 80GB hardrive - error 6
Install your previous hardrive as a slave, secondary drive to your new one, or easier still, buy an external enclosure for it and connect to it via usb
May 16, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
HDS728080PLAT20
the comp detecting the HDD is irrevelant, the fact it detects it means only it has detected the electronic part of the drive, if the actual mechanical part of the drive, and the platter are failing, then it will not work, i suggest taking it to someone who can test it.. you will know then
Dec 08, 2007 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
