Question about Canon C3380i Color Copier
Only wants to print/copy on Legal paper
I think that one of the guys in the office messed up the settings....now the copier only wants to print/copy on legal paper - help! i have tried holding the 'reset' button but it doesnt work...
  • 78 Answers
Check that someone hasnt moved the paper size dial blue 1 in paper trays then do get device status in driver for printing my moneys on the dial been moved
Posted on Nov 30, 2009
Having reduced 3 inches missing copy print of Legal page (8.5 x 13)
Hi..
me too having same problem in MS Office..but finally i observed sometimes paper sizes or faulty..so try to reduce the paper size..
Apr 05, 2014 | Konica Minolta Bizhub 500...
Legal size copies paper
function/ general settings/ key op/ 000 / cassette settings
Sep 14, 2013 | Panasonic DP-8016P Copier
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
HP Office jet plus 8600+ - supposed to print legal but does not!!?!
The printer set up procedure may reveal there is no provision for legal size printing.
May 26, 2017 | HP OfficeJet Pro K8600 Printer
We tried printing and copying with the setting set at LTR and LTR-R and we checked the paper tray and every time we make a copy or print it prints out the entire document perfectly centered across the...
It seems to me to be a problem of the Blue paper cassette size dial is set wrong. First see what the settings are from the display by pressing the paper select button. Most people have it set for the upper cassette to be LTR ( 8 1/2 X 11 inch paper - length running from front to rear in the cassette ) and the lower cassette to be LTR-R ( 8 1/2 X 11 inch ) or Legal ( paper length running left to right). Check to make sure the blue dial agrees with what's in the cassette. Try doing the testing by putting the paper on the glass first and closing the top. If this is correct and the problem is in the Documnet feeder then one of the raised flags may be broken or the sensor bad. The left one is for letter, the second one for LTR-R or legal and the third is for 11 X 17. The opening and closing fo the side guides also helps to determine paper size. Hope this helps you.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
Change legal size to letter size
scan it as a document, re-scale it in required size and save then print in required size.
these adjustments are in your word or office programs. if you need to make it to copy, insert your original in the scanner, in paper tray insert your letter paper, select copy and then re-size, this should do it "on the run".
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
Coping Copies of Legal Size
For either a Printer or Copier, the 1st thing is you have to use full-size LEGAL paper. If your copier won't accept this, then you cannot do it. It has to fit in the paper tray.
Second, use the setup menu of your copier and set paper to 8.5 by 14 or LEGAL size, for a Printer
goto Start, Settings, Printers and Networks and find your printer/copier, Right click it, select Properties, select General or Paper tab and look for Advanced Settings. There you will find Paper Size pull down. Change it to Legal, Click Apply, Click Close
Done!
Mar 26, 2009 | Office Equipment & Supplies
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Canon C3380i Color Copier Logo
57 people viewed this question
old marine
old marine
