Question about Kenwood KAC-929 Car Audio Amplifier
Can you power 2-10" subs and 2-6x9 speakers with this amp?
    President:
  • 676 Answers
You could but the only problem is even if you ran the speakers in parallel, meaning + to + and - to -, the best power you would get out of the amp is 230 watts per channel. Would probably make your 6x9 sound good but not enough to push your 10's.
Posted on Nov 19, 2009
Speakers cutting in and out at high volume
The amp is going into protect on the two channels powering the speakers. Turn down the gain on those two channels. You also may want to consider crossing over the speakers a little higher than they are now.
The rating on those speakers are way too high. 6.5's and 6x9's will take 50-100 clean watts tops before they start to break up.
The best solution to get it perfect is....unplug the subs. Turn the gain on the speaker channels all the way down. Then turn up the deck 80% as high as it will go. Play a song. Then increase the gain on the amp until the speakers are as load as they go without distortion. Shut off the car, replugg in the subs and do the same thing. Gain on sub channels all the way down, deck then to 80%, find a bass heavy song, then turn gain up until subs become distorted. If you do this procedure your speakers and subs will be "gain matched" to the proper levels.
Good Luck
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
I have a 400w rms @ 4ohm sub. What amp do i need? If i want to connect it via 2 channel, bridgeable amp, what wattage does each channel need to be? Do i need a second amp for 2 6x9s?
almost any amplifier amp would push a 400 watt sub. try to stick with a name brand, and steer away from no name brands like boss, jensen, etc.you will only need a 2 channel amp to run your sub.you will need a second amp to run your 6x9'sor you could get a 5 channel amp, and run all your speakers, and the 5th channel for your sub
Oct 25, 2012 | Car Audio & Video
Hi i just got 2 new infinity 860w reference 8'' subs 250 rms each and pushing it with sony 600watt amp pushing it but very low sound and no bass why the othier speakers i have in 10'' hit the bass fine but...
The amp may no thav eenough to push these subs, these are top of the line subs, they probably require a bigger amp, if you are running other speakers through this also, you certainly need another amp, or a bigger one with more channels. also double check all your wiring.
Mar 29, 2011 | Jl Audio 12W7 Car Subwoofer
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
Speaker sizes
3 1/2" Mid range on dash, 6 1/2" Mids in the driver and passenger doors, 6X9"'s in the rear seat, and added (2) 10" Rockford Punch Phase 2 subs in the cargo area with a Rockford 3000 W. amp to power. Sounds Great!
Oct 17, 2008 | 1998 GMC Jimmy
Will this amp push my speakers
Whoa, I do belive your rating for your speakers are inflated. I have never heard of a 6X9 accepting 800 watts thats just rediculas, its more than my 12" sub needs. Anyways, if this amp is anywhere from 300 to 500 RMS watts you will be fine. Because the speakers are small they need very little wattage to reach there potential, usually less than 100 Watts each, and probably around 50. If you think about it most decks put out 50Watts max for each channel, because that is the max you can assume that the RMS wattage of the unit is only around 20-25 Watts of power per speaker.
Mar 25, 2007 | AudioBahn A4401Q Car Audio Amplifier
Kenwood KAC-929 Car Audio Amplifier Logo
100 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
