Question about Sony Playstation 3 (PS3) Console
The PS3 is not taking in any discs, when i attemp it the disc just slides in and out with no problem. when i attemp to press the eject button it does the usuall sound and blue led flashing but i can also hear the rotors to **** in discs spinning
    President:
  • 2,653 Answers
Is it making like a clicking noise? Give me details, I can help!
Posted on Nov 20, 2009
Ps3 freezing and disc wont read and skips
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
Take care.
I wish you good luck
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
The disc is jammed, it tries to come out but doesnt quite make it....HELP!! :-(
Press and hold the console's eject button for 10 seconds. This will restart the mechanism that is in charge of taking in and ejecting a disc. As long as the console isn't jamming as the result of a series hardware problem, this will eject the disc.
May 27, 2011 | Sony Playstation 3 (PS3) Console
Hi I have a ps3 slim and it just recently stopped ejecting my disks.when I press the eject button the ps3 makes a clicking sound but nothing comes out.but if I turn it off then back on it makes the noise...
He is full of **** trying to scam you. It sounds like your disc drive is out of alignment with the top part of the disc drive so the clicking your hearing is the bottom of your disc drive trying to eject and the top is holding its on as the top has sliding parts that meet perfectly with the bottom part of the disc drive so it sucks the game in and out. You need to open it yourself with a philips head screwdriver you dont have to worry about the motherboard or any other part just take the drive out undo the ribbons connect the drive to the motherboard then it should pop right out. Been awhile since I took a slim apart they dont break as often (yet). From here you should have a metal caseing over the disc drive maybe not with the slim. You pop the metal caseing off the you have a plastic disc drive. Take the top part off maybe requires small phillips screw driver. Since you have a disc in it when you take the lid off hook the cables back to the ps3 motherboard and to the cd drive. Now press eject with the top lid off. Then put the top lid back on and insert a disc it should work. Then just put it back together. Theres a little motherboard on that cd drive do not short it out on anything. You can do this if you cant worst is youll have to buy a new cd drive from the repair shop you mentioned. Then they should charge to much labor to put it back together as you had it apart when you got there. But you should beable to do it if you need help taking it apart just google or youtube slim ps3 disc drive repair or how to take apart slim ps3. Hope this helps if not let me know.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Red light flashes when turned on, cant even eject disc
Try to do these 3 things.1 - Restart your console.
2 - Take out all cables, and plug them back in.
3 - Take out the hard-drive, and place it back in your PS3 console.
Try this to take the disc out:
1. turn the PS3 off from the back
2. Put a finger on eject button
3. then turn PS3 on from back with finger still on eject button
4. disk should come out
May 07, 2010 | Sony Playstation 3 (PS3) Console
My disk is not ejecting from my ps3. my pro evo 2009 has been stuck in for a while now. when te eject button is pressed it attempts to do so but then nothing comes out and it goes back to normal (as if...
is there a tiny whole in your ps3? in which you could insert a small pin? if not. then the disc tray may be stuck. you could try lifting the disc tray with a pliers or something that can hold the tray and slowly pull the disc tray as you press the eject tray. Pm me for any clarifications.
Aug 07, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 WILL NOT EJECT BLU RAY MOVIE
press and hold eject button for around 15 seconds, it resets the cd drive, hope this helps
Jan 28, 2009 | Sony Playstation 3 (PS3) Console
Disk will not go into PS3 appears to be blocked
Press and hold the eject button for around 15 seconds, this resets the cd drive and will fix your problems. Hope this helps
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Wont accept disc
Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
(PSN ID is Burnsy333)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Disc is stuck in ps3 drive
trying sticking something thin and firm in there gently.. try to feel for the bottom side of the disc. Press the eject button and press up a few times. This may take awhile. But Be sure to be very Very gentle while doing this.
Aug 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 jammed disc
Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
