Question about Bunn BT10B Coffee Maker
The part you pour the water in leakshow do i fix or get new part
    Problem Solver:
  • 9 Answers
Hi - I had the same problem and wrote to Bunn via their CS link on their website, www.bunn.com , this was their helpful response:
Thank you for contacting Bunn O Matic.
I am ordering the parts and instructions needed to repair your machine. Those parts should arrive in 7 to 10 working days.
The repair kit does not include the water tray, but is designed to repair the area where the leak is occurring, even if the plastic is worn away. The water tray is not available from the factory.
Although there is no charge for these parts, if for any reason the repair doesn’t work, or if the machine leaks at a later date, that would mean your machine is not repairable. However, if your machine is not repairable, it would be eligible for our Exchange Program.
With the exchange program, your machine can be sent to the factory and exchanged for a new brewer at a savings of $30 to $40 off the retail price of a new machine.
If the repair doesn’t work, and you do want to exchange your machine for a new brewer, please go to our Web site, www.bunnomatic.com. When at our Web site’s Home Page, click on the “at Home” link. On the next page that comes up, click on the link for “Customer Support”. Once the drop-down menu appears, please click on “Parts and Services.” Make sure you fill out all areas on the “Parts and Services” form, including the model of the machine, the code number, and the exchange box. Once the form is completed, click on the Submit button.
Once I receive your form, I will let you know the procedures to follow to exchange your machine for a new brewer.
Thank you
Posted on Mar 25, 2010
  • 131 Answers
I presume that you are talking about the plastic pour-in tray, as this is the cause of most of these brewers leaking. I have seen some people repair these using hot glue, but that is a very temp. solution at best. The best way to repair these is to replace that tray. Maybe try your local Bunn repair facility to see if they have a used one hanging around. You can find your local service center on a list at www.bunn.com
Posted on Nov 26, 2009
My Samsung washing machine wont stop with water filling
First clean the detergent drawer and button trap, then make sure the siphon cap {it might say "MAX" on it) is installed properly. Make sure water pressure is not too high.
Apr 18, 2016 | Samsung Washing Machines
Brita filter
When you initially soak the bag in water make sure to squeeze it lightly and shake to release all the air bubbles. Also, you should pour out the first couple pitchers of water after using a new filter as it takes time to break in. This way all of the gray or black filter water will be gone by the time you wish to drink. For more water filter and pitchers go to www.freshwatersystems.com.
Jul 09, 2014 | Water Filters & Coolers
I put water in and coffee and it never pours the water out
Seized up air pump/ motor...just fixed mine..kinda a pita to do but not very hard to clean or replace
Mar 14, 2014 | KUERIG Keurig Platinum B70 Brewing System
Water pouring out the vent back into the reservoir...
i have a water problem but mine is .. when i turn the machine on it just starts pouring water out and does not stop.. and the machine still says not ready all the time the water is pouring out.. anybody know how to fix this ??
Jun 20, 2010 | Keurig Elite B40 Coffee Maker
It overheated, smoking and water pouring
If water poured out you probably busted a hose or radiator sprung a leak. Sounds like that and a bad thermostat or water pump went out.
May 10, 2010 | 1991 Buick Century
Whirlpool washer pours water on right side
The pumps on these washer wear out over time and leak.
While replacing the pump, you should replace the direct drive coupling also. That is part of the torn rubber gasket you are referring to.
This video will show you access to the parts.
Apr 22, 2009 | Whirlpool Washing Machines
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Leaking pour basin
Your only hope of getting a new tray for these would be if your local Bunn repair shop has some hanging around that broke down for another reason. This is a very common problem with those models. You can find a list of Bunn repair depots at www.bunn.com Good luck!
Jan 21, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Water pouring out from under cherokee as fast as i pour in
you need to get it checked out by someone with mechanical knowledge as it may be a freeze plug or cracked pump housing, burst radiator, just try to see where the water is coming out if you can while you pour it in.
Nov 28, 2008 | 1990 Jeep Cherokee Limited
Bunn BT10B Coffee Maker Logo
198 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
