Question about AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 - the door will not open even though it releases.
SOURCE: Door locked
Rather than taking the top off the machine and fiddling around to find the catch as guest suggests, I got it to open with some strong string. I took a fairly long piece and threaded it into the groove where the door joins the metal front of the machine, on the catch side of the door. Then pull both ends of the string very hard to the left (you may want to wear gloves to protect your hands). Pull hard and move the string up and down until the door opens. Worked for me.
Posted on Feb 15, 2008
  • 24 Answers
SOURCE: operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Posted on Aug 03, 2008
SOURCE: I have an AEG Lavamat 16820 washer dryer and the
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
Posted on May 12, 2009
SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Posted on Nov 11, 2009
beltronic205
  • 1460 Answers
SOURCE: AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Posted on Nov 12, 2009
WHAT IS ERROR E40 MEAN?
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810
E10 is related to water flow and if it isn't due to the 3-way valve being defective there's another common point to check.
The back and side cover needs to be removed to get at the condenser that, over time, can fill with fluff and stop the hot air from circulating. It and its connecting pipes can be unclipped and cleaned out.
Oct 17, 2013 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
I have an AEG Lavamat 16820 washer dryer and the door wont open any ideas
May 04, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
I need help fixing my washing machine
fluss saup box vith hott vater i 5,min remeber have open fra the pumt end fluss
Nov 25, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Door wont open
Hi Corin This is not a solution, apologies! It's just that I have exactly the same problem - did you manage to fix it? Ondine
Sep 25, 2006 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
117 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
