Question about Samsung SCX-4500 Laser Printer
Problem! When turned on, printer shows an error indicating red triangle and printer starts vibrating and making noice for aprox 10 seconds...paper is noy jamed, and troubleshoot program doesn't help...
    President:
  • 2,306 Answers
The vibrating could be a problem with the fuser gears, they sometimes break from heat and lack of lube, you should have a shop check it out before the vibrating causes more damage.
Posted on Nov 19, 2009
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
Printer Canon 240PM It stopped printing and despays P8
on the printer you have a buton called resume/cancel; it has on it a red circle and in the circle a red triangle; hold that buton for at least 10 seconds and the error should go away; if it still shows the error hold one more time the same buton for at least 10 seconds, after that power off and power on the printer.
your printer will never show the amount of ink in the cartridges again until you put in new and original ones but it will print scan & copy like it is new.
Nov 13, 2010 | Canon PIXMA MP240 All-In-One InkJet...
What does it mean when the ! light is flashing?
The caution light indicates an error with the printer in either toner delivery, paper jam, or misfeed. First step is to look at menu LCD and it typically will represent the error. After that I woudl try reseating the toner cartridge in the printer to make sure it is firmly and correctly placed. Also make sure it is not empty. Finally remove the paper tray and inspect for a misfeed or jam. If you have verified all items are correct and there is plenty of toner then unplug the printer from power supply and while UNPLUGGED hold power button down for 10 seconds. Then plug back in and turn it on. If the same exclamation point is showing then you may have a gear problem
Jun 30, 2010 | HP LaserJet P2015dn Printer
U130 ink message on pixma mp620
Very simple solution: When the pixma mp620 screen shows error U130, Hold down the stop (red triangle) key for about 7 - 10 seconds. This overrides/turns off the ink monitoring function. The printer will begin "thinking" for a bit and then start printing. Note: you may have to do this seperately for each color. You'll also notice that when the lid is open and the cartridges are in position for changing, the cartridges that used to be "out" are no longer flashing red, nor a stead red. They are dark.
Feb 17, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Every time I try to print the paper jams. All the paper has been removed, turned it off, still jamming
Found this on the Web, hope it helps you.
If you find this helpful, pls rate me.
Turn your printer off for about 10 seconds, remove the printer cable and then turn the printer back-on. Does only the Green Power Light come on solid [not blinking], as would be normal, or does the Red Error Light also come on? If only the green power light comes on, then try running your printers self-test page, directly from the printer. On most epson printers you can usually run an self-test page to determine whether a problem comes from the printer itself, or possibly from your computer system. Of course if there are actually any red error lights/leds, already showing on your printer, that would indicate that there is already a problem in your printer. Not all epson printers are always the same, but the following information applies to most models. If this self-test does not actually work on your particular printer, then you should refer to your "User's Manual/Owners Manual" for the correct procedure on how to run your printers self-test page. First unhook/unplug the printer cable from the back or side of the printer. Leave the power cord still plugged in to the wall and leave the paper loaded, as normal. Turn the printer off for 10 seconds or so, to clear out any remaining DATA or information that may still have been in the printers system, from when the computer was previously connected. Normally [on most models], you turn the printer off and then you simply reach over and hold-in on the paper button, while you reach over and turn the power button back on, as normal. Continue to hold in on the paper button for about 3 to 5 seconds, but release the power button after turning your printer on. Release the paper button once you can hear and see the printer starting to initialize and start to pull-in a piece of paper. The printer will normally print out the self-test copy, which will also have a nozzle test on it. If that test fails, or cannot actually be ran because the "Red Error Lights" come on, then you know that there is an actual problem in the printer. Depending on the combination of which lights are on SOLID, or FLASHING or OFF, will actually indicate the possible service error condition. Be sure and let us know if you recently had to remove any bad paper jams, by yanking out the paper with force, especially towards the rear of the printer, in the backwards direction. There is a common problem when you get a constant jam condition, or paper won't feed in correctly after a bad jam was removed, or even when the printer or your computer thinks that the paper has not been correctly loaded. If that is the case, then its possible that a part was unhooked/unseated or even damaged, causing a possible constant paper jam condition. If you did have a bad jam, prior to the paper feeding problem, then let us know and we can try to help you further...ON THE OTHER HAND: If everything is working correctly in the printers Paper Feed Assembly, Carriage Assembly/Cartridge Assembly and the Printhead Assembly, then the self-test copy should be printed out and correctly fed thru the printer. If the self-test page prints out correctly and the nozzle test looks ok, then that indicates that your printer thinks it is working normally [as far as the self-test goes].
Thanks and Good Luck.
Jan 25, 2010 | Epson Stylus CX6000 All-In-One InkJet...
I have a Canon MulitPass MP730. Wrong Cartridge message.
It's worth repairing, That error on a Canon is saying that the printhead is bad, not your cartridges. The part number for your printhead is stamped on the side of the printhead could be QY6-0049-000 but I'm not sure.
Jan 10, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Red Indicator Light stays on-- "Online Error."
tray to powering off the printer wait about 10 second then swith on
i use to be too
Apr 29, 2009 | Samsung ML 2010 Laser Printer
I have a Samsung ML 2510 printer. It was printing just fine and then the red light below the triangle with the exclamation in it came on. When I send jobs to the printer nothing happens. I have checked...
Toner in your catridge might be over. Turn off printer. Click Start, settings, printers and faxes. Make sure it is your default printer and double click on it. Cancel all the pending jobs. When everything is deleted close the box and turn the printer on and continue your job.
Dec 17, 2008 | Computers & Internet
The led screen shows genera error
you need to reset your printer try doing this
  • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
  • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Nov 24, 2008 | Epson Stylus Photo R300 InkJet Printer
Pixma mp150 error code 5
This error 5 appeared. Need to know what it is and how do we fix it. Help!!!!
Aug 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Samsung SCX-4500 Laser Printer Logo
308 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
