Question about Mitsubishi WD-62528 62" LCD HDTV
HAVE REAR PORJECTION TV #62528 TOO IN FOR REPAIRS HASN'T WORKED FOR 2 YEARS (TRIED TO GET SERVICED BY RECOMMENDED TECHNICIANS)WAS TOLD IT NEEDE A LIGHT ENGINE MOTOR (SOMETHING LIKE THAT) CAN U TELL ME IF U KNOW THE APPROXIMATE COST OF THE PART? IT MADE A LOUD SOUND LIKE THE FAN GOING AROUND ONLY LOUD AND THE PICTURE WAS BLACK TRIED REPLACING BULB LASTED FOR 1 DAY AND WENT BLACK AGAIN...
My screen is almost totally blue., it started on the left side of screen like a blue blob, now it is almost my whole sccreen,,what is wrong?
Posted on May 08, 2011
  • 834 Answers
Light engine is around 567 dollars
Posted on Nov 19, 2009
Fixing the convergence on a sony rear porjection tv
AUTO CONVERGENCE OFFSETS
IMPORTANT
This adjustment must be performed after registration adjustment
or after readjustment for any reason!
Once registration in all modes is satisfactory, do the following:
1. Darken the room environment near the set.
2. Enter the monoscope signal to set the NTSC Full mode.
3. Select the PJE mode.
4. To automatically store the offset values, press the "FLASH FOCUS"
button on the front panel of the set.
(The offset value is now stored)
5. Select "ERR" of PJE mode.
Confi rm ERR is "00".
If ERR is not "00", recheck. (Refer to section 2-15)
6. Exit the service mode.
To get more details about how to enter service mode option, check this link, and select the site named 'Electro-help'. all details are there.
Jul 10, 2012 | Sony KP-53HS20 TV
A have a KP-43HT20 43 in. rear porjection tv, and everything works on it but i cant get a cable connection on it now!! it keeps saying no signal!!! its not my cable provider, its the tv!!! please help!!...
hello, how have you got it setup, the aerial should go straight in to you cable box RF1 then a second lead from RF2 in to the tv, then reconnect your scart leads,try retuning your tv.fingers crossed.
regards
shaun
Dec 04, 2010 | Sony KP-43HT20 43" Rear Projection...
Installing PS3 with HDMI
there must be a HDMI option in the picture settings on the tv and select 1080i or 1080p in the ps3 video output settings
Sep 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA P61927
You are describing a convergence issue. Rear projection CRT sets use THREE separate color 'guns' that need to be aimed properly every so often, sometimes every month, sometimes once every year, but usually when its moved. Convergence operations are typically a user serviceable function and the process can be started from the menu.  If you have tried doing the user convergence and it is still a bit off you will need to get it to a repair technician that can either fix the power supply or mechanically align the guns.  In my many years of TV experience, rear projection CRT's are typically discarded for two main reasons; either the power supply is causing convergence issues or the blue gun is dull or dead. Either way if you cannot perform a convergence yourself you are looking at $200+ in repair and parts. I would suggest finding a local television repair technician, not many left I know, and get a quote.
May 26, 2008 | RCA P52926 52" Rear Projection Television
DVD stuck in player
We've been ripped off! I've learned my lesson about "Mintek" have you?
Feb 22, 2008 | Mintek DTV-263 26 in. LCD Television
BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Mike
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
No Picture no sound.
This fault sounds like a high voltage shutdown or the high voltage fault. It is not a repair thst a regular handyman should attempt to repair unless they have electronic background. I you want to attemtp yjr repair yourself and you understand the technical lingo then you can get a schematic diagram and start to troublrshoot the horizontal out section and move your way through to the main power supply but I bet you find a short in the first place I said Good Luck
May 29, 2006 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi WD-62528 62" LCD HDTV Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
