Question about Belkin (F5D5231-4) Router
Belkin150 modem light is amber and now it wont work
I cloned the MAC address and the modem light is amber even after restoring to default settings. It explicitly said it will not affect the network...and yet it seems my router is broken. the cable modem still has internet, but router will not recognize it.
  • Belkin Master
  • 6,487 Answers
Try first resetting the router by pressing the reset button of the router for 15 seconds while power is ON and then try to reconfigure it again but if still not working this can already mean that the router is bad and needs replacement.....
Posted on Nov 21, 2009
I have a new belkin n150 when i conect to the modem, there is a amber flash light for the modem on the router, when i conect the computer directly i have conection, i have folowed all the instructions but...
This indicates that router can't detect cable modem or this is unresponsive, probably your modem is logically tied with your PC (MAC address associated), that's why when you connect them directly work fine, if this is the case, you'll have to clone the MAC address of your PC into your router, this should be at Setup Menu, Manage MAC addresses option.
Feb 21, 2011 | Belkin N150 Enhanced Wireless Router...
Tip
Configuring Belkin routers without installation CD for Cable ISP: ·
Configuring Belkin routers without installation CD for Cable ISP :
  • Connect the cable Modem/ Ethernet cable from ISP to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:Check for the internet status at the top right hand corner. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
If it is not connected then we need to configure by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next.
Step 3: HOST NAME leave it blank or you can type anything there and click on APPLY CHANGES.
Step 4: Click on MAC ADDRESS or MAC CLONE (found right below the connection type on left side of RSP).
Step 5: click on the button CLONE (once you click on clone the MAC address will get changed) and click on APPLY CHANGES.
Step 6: Before doing MAC clone one important thing has to be noticed. Check whether you are able to go online when you connect the computer directly to the cable modem. Because Cable ISPs uses a particular kind of authentication called MAC authentication. Hence, only the particular computers whose MAC addresses are registered in their database will be able to go online directly from the modem.
***MAC clone is a feature that copies the MAC address of your computer and pastes it in the router. So the router will have the MAC address of your computer and it will get connected to the internet.
Step 7: Now check for the internet status at the top right hand corner. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
  • Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
  • If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected.In this case you need to repeat the above Network power cycle by unplugging the cable that is going into the cable modem from the wall outlet.
  • Still if the internet status is not connected, then connect your computer directly to the modem and check whether you are able to go online.
  • If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
your wired part is configured completely now.To configure the wireless part click here
on May 05, 2010 | Computers & Internet
Cant seem to connect to the internet local access only
Connect Modem cable to Modem port of the Belkin Router Check the light status Flashing Amber-- Issue with Physical connection (Check Cables) Steady Amber-- Needs to be configured Follow these steps Open Web Browsers like Internet Explroer or Safari Type in Web address bar 192.168.2.1 For Password Leave the BOX blank and click on submit Torwards the left side you can find Restore Factory Defaults Click on it Restore Defaults> Click on OK for Disclaimers Then select Connection Type, then select Dynamic>Host name ( put your computer name)> Click on SUBMIT
Select MAC ADDRESS( towards left side)> select CLONE
Then Reboot both Modem and Router Hope it will fx the issue for You
STEADY GREEN-- Ready to use the internet Flashing Green--- Router is booting up
((((((FOR HARDRESET -- Behind the router you can find reset hole... Press and Hold with any sharp object (toothpick or Paper clip) for 40 secs))))
Dec 09, 2010 | Belkin Basic Wireless Router
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
My belkin back up dont work and only 1 orange light appears on the route
ISSUE: Flashing amber modem light in the Belkin Router and won't connect to modem or computer
SOLUTION:
Step 1: First hard wire Modem>Router>Computer
Step 2: Open internet explorer and type in this (192.168.2.1) address in address bar
Step 3: You see Belkin Router Ste Up Page
Step 4: In top right corner you can find internet status it would say Connected or Not Connected
Step 5: In your for left left screeen you can find list of options in that click on "Restore Factory Default"
Step 6: It will ask you password leave it balnk and click "SUBMIT"
Step 7: Click on "Restore Defaults" Button and It will show you two warning messages click "OK" "OK"
Step 8: Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 9: In your for left left screeen click on "MAC Address"
Step 10:It will ask you password leave it balnk and click "SUBMIT"
Step 11:You can see Clone computer's MAC address Button Click on It "CLONE"
Step 12:Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 13:In top right corner you can find internet status it would say Connected if its not
Step 14:Unplug the Power Cord from MODEM and RUTER wait for 2 minutes
Step 15:Plug the Power cord to Modem first and wait for 2 miuntes
Step 16:Plug the Power cord to Router and wait for 2 miuntes
Step 17:You can see Modem light in router will lit up standerd Green
Step 18:In top right corner you can find internet status it would say Connected
Step 19:Now your Good to go.... Check you can go online..Good Luck...Budy
If you need any help ....Please P.M me..... I'M here to help you all....
Thanks&Regards,
Karthi.J
Apr 19, 2010 | Belkin (F5D5231-4) Router
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
Re-Connectivity to Comcast Modem
All you need to do is "MAC ADDRESS CLONING". Access the router's setup page and look for MAC Clone settings. Enable that and clone the mac address of your main PC. After that, perform a power cycle. Turn off the router then the modem. Wait for 30 seconds then power on the modem first, wait for all the lights to go solid then power on the router. That should do it.
Apr 15, 2009 | NetGear RangeMax WPN824 Router
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D5231-4) Router Logo
144 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
