Question about New Home L-372 Mechanical Sewing Machine
I have a New Home model # 352 used sewing machine. I cannot figure out how to thread it. Help!
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
  • 323 Answers
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Sewman7
Posted on Mar 20, 2009
  • 980 Answers
SOURCE: singer 457 bobbin thread not "catching"
Providing you have put a new needle in the correct way round if the machine is not picking up the thread it may need retiming, email me and I will attach full instructions if that is the problem.
drivewithken@blueyonder.co.uk
Posted on Jun 27, 2009
How to thread 960 new home sewing machine
Perhaps this will help. Machines tend to thread similarly unless there was a big change between models.
New Home Model 532 Sewing Machine Threading Diagram
Feb 27, 2017 | New Home Sewing Machines
I have a Finesse new home 23 4 overlocker. How do I start the threading please.
A manual would be helpful:
Instruction Manual Janome Newhome 234
Even if you are unable to find a manual for your particular model, similar models usually thread the same or similarly. Just be sure to ALWAYS RAISE the presser foot when threading the machine so the thread will seat in the tension disks.
New Home Sewing Machine Manuals PDF and CD
Janome New Home sewing machine instruction manuals
Make It Handmade Threading Your Serger or Overlocker
Nov 25, 2016 | New Home Sewing Machines
How to thread this machine
or search the internet for:
New Home + (Model #) + threading diagram
Hint: Always Raise the Presser Foot when threading the upper thread. This insures the thread will seat properly in the tension disk.
Jul 20, 2016 | Sewing Machines
Why won't my new home super stretch stitch model-844 pick up bobbin thread to sew manual book
If you need a manual, search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Try installing a brand new needle. A bent needle sometimes will not connect properly. Be sure that both upper and bobbin threads are threaded correctly.
On the other hand, the needle/hook could be out of time. You can check that by hand turning the handwheel and watching the needle/hook movement. There are a multitude of web sites and videos that discuss timing. Or--check with a sewing machine technician.
Mar 20, 2016 | New Home Sewing Machines
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
May 26, 2017 | New Home Sewing Machines
A friend asked me to thread her Janome 352 sewing machine without instruction book. The solution posted assumes that I know what all the parts are but although I have sewed for 30+ years I couldn't...
you can go to www.sewing.about.com and check out Debbie's sewing machines 101 guide. She has images, diagrams and general threading up.
or your friend can purchase a manual from here http://ifixmachines.com/vmchk/Janome-Model-352/Janome-352-Sewing-Machine-Manual/ilvm_fly1_blue.tpl.html
tally_girl_30.jpg looking at this image I would say "raise the pressure foot, take the thread from the spool holder at rear of the machine and take to the left and through the first thread guide (cant see one but there will be) then down the right side of the metal flat thing, through the guide at the bottom, then back up the other side of the metal thing and through the take up lever (turn fly wheel until this is tat its highest point to get access) then back downwards, through the thread eye near lower edge of machine head, then down to the needle bar thread guide and through the needle.
The tension device will be in that top area where the metal piece is and the horizontal white dial on left will be tension control dial.
I hope this helps you and your friend out, 4 thumbs up if so :-)
May 31, 2011 | Sewing Machines
I need to know hao th thread my janmone sewing
If you can email a picture I can help you drivewithken@blueyonder.co.uk
Mar 23, 2010 | Sewing Machines
I have a New Home Limited Edition Model with
i need help to fixe my house and i need moneyto gate my work autorization
Dec 09, 2009 | New Home Sewing Machines
New Home L-372 Mechanical Sewing Machine Logo
244 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
