Question about Refrigerators
Sometimes when ice is dispensed, the door remains open, and has to be manually closed by inserting a finger through the spout. this is not a good practice.
  • Refrigerators Master
  • 19,396 Answers
Hi.
You may need to replace the dispenser door lock.
To get part and diagram, please give me the complete model number of your fridge, as written on service tag.
Thanks.
Posted on Nov 19, 2009
I have major ice build up in the freezer near the icemaker area of my GE side by side. Replaced the icemaker, but the problem came right back. HELP!
Icemaker inlet water valve may need replacing. If the valve
is not closing all the way it will leak water into ice tray.
Sometimes well water without a conditioner can cause
cause this problem. LynnMBent
Oct 27, 2015 | GE Refrigerators
My wife noticed our side-by-side GE Turbo Cool water dispenser was dripping water so a quick look in freezer showed a huge ice buildup in the drip tray that had frozen back into the spout. We emptied both...
let see if I understood correct me if i'm wrong! When you close the freezer door water star running from the dispenser? If so you water valve solenoid is staying in the open position just replace it.
Dec 21, 2014 | Refrigerators
My ice maker is making snow in the dispenser area---What can I do to resolve this?
I would look at the dispenser door to be the issue not the ice maker. This door if not closed will allow warm air to enter the freezer and create frost.
You would look into the dispenser door and clear the ice out, use a flashlight, open and close the dispenser door, if you see light after this. replace the dispenser door and or bar, spring, or other related part to the dispenser.
Good Luck
Oct 12, 2011 | Kenmore Side by Side Refrigerator
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
Frigidaire frs26r4a after opening and closing freezer door all panel lights are on - both cube and crushed ice panel indicators, and the light that illuminates the water and ice dispenser remains on until...
The only thing that I can see that would cause that is a broken freezer door light switch and possibly the power going through the adaptive defrost. Broken or fused to cause the power to come on when the door is closed...Click Here=> FRS26R4A I blieve i can help you with this if you are willing to work and communicate with me, Thanks Sea Breeze
Dec 25, 2010 | Frigidaire FRS26R4A Side by Side...
ICEMAKER FROSTING UP
Try to take some ice from the dispenser. Remove the glass and open the freezer door to look down inside the dispenser chute and see if the trap door has re-closed. If it remains open warm, humid air will enter the ice bucket and gradually freeze the cubes together. Trap door remaining open is generally caused by a rusted electrical coil which pulls the door open electrically then sticks, unable to re-close. Coil is located behind the panel that operates the dispenser. Relatively easily accessible.
Jul 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice on door not dispensing
you can look closely under the front facade of the dispensor itelf, youll seee 2 small slits approx 2 inches in from each side, insert a flat blade screw driver into the slot and it should "pop" off then lift it off. when putting back on hook the top and push down as close as possible, sometimes I have to hit them with the palm of hand in order to get to "snap" back into place.pushing down on the top of the facade will also ease in the removal
Apr 08, 2008 | Amana ACD2232HR Side by Side Refrigerator
Whirlpool In-Door-Ice® Ice Dispensing System
the dispenser front "pops" off by inserting a screwdriver under he dispenser front, look closely youll see 2 little slits where ot insert and twist from. as your inserting and twisting would be helpful to be pushing down on the top of the facade.(just plastic tabs holding on care full not to break. its pretty apparent after that. when re-installing Hang over the top and kinda give it a good smack down with the heel of your hand... but honestly before all that look at the wires under the door hinge make sure there are no cut wires. ( a natural pinchpoint created by the hinge mechanism)
Mar 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
