Question about Jensen VM9510 Car DVD Player
Pink wire parking brake problem
IT HAS TO BE TO THE CHASIS GROUND.?????
Posted on Jan 15, 2008
Conect the brake wire to the Chasis ground
Posted on Jan 11, 2008
Where does the pink praking brake wire go on 2003 cadillac deville go
Where are you seeing this pink wire ? I'm looking at a wiring diagram and I see a pink wire at the (RIM) rear integration module . It goes to the park brake relay A ,control side . The RIM supply's a ground on that circuit energizing the park brake relay A . There is another park brake relay - B . Are you familiar with the RIM module .
The park brake system is a mechanical and electrical system which operates on the rear disc brakes. The system is activated by depressing a foot pedal lever assembly, which sets the rear brake caliper via cables. The park brake is released by shifting the vehicle out of park or activating the manual release.
Park Brake Release
The rear integration module (RIM) controls the operation of the electric release park brake. The RIM uses serial data messages to determine if the correct conditions exist to release the park brake. The park brake is released under the following conditions:
• The engine is ON.
• The gear shift lever is not in Park or Neutral.
• The park brake switch is closed.
When all of the above conditions exist, the RIM releases the park brake by simultaneously activating the 2 park brake solenoids. After 2 seconds, the RIM deactivates solenoid A. The RIM continues to activate solenoid B while the above conditions exist, which prevents the park brake from being set.
Dec 23, 2016 | Cadillac DeVille Cars & Trucks
I have a Jensen vx7010. How do I bypass the parking brake inhibitor?
I found a .pdf user\'s manual that states:
"When the pink \'Parking\' wire is connected to the vehicle Parking Brake circuit, the front TFT monitor will display video when the Parking Brake is engaged. "
So I imagine it\'s a simple disconnect of the pink parking wire. However, I would not recommend this as it seems to be illegal if you are caught with the video running while you\'re driving.
Dec 02, 2014 | Car Audio & Video
What color wire do i hook the pink wire to
Pink wire is generally the parking brake safety. If you dont want the dvd player to play video while in drive wire it to the ground on your parking brake sensor wire. If you do want it to play video while your driving, wire it directly back to the ground wire on your stereo.
May 15, 2010 | Alpine IVA-D300 Car DVD Player
Vm 9022 jensen how to connect a pink wire
i am not too sure what u realy want. but if the pink wire is connected to the parking brake u can only view videos when the parking brake is engaged but if you want to view videos all the time or anytime just disconnect the pink wire from its current connection and reconnect it to the vehicle's chasis
Nov 26, 2008 | Car Audio & Video
Parking brake
If you have the VM9410 then there is a way to play dvd's even when you are driving. You must ground out the pink wire in the harness. This allows you to watch dvd's even when driving. good luck!
Feb 24, 2008 | Jensen VM9410 Car DVD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Xo vision xod-1730 product showing no image?
to watch dvd video on xod1730 like what adamdog said you need to attach/mix the pink/braking wire to black/ground wire and if you want to disable the pink/braking wire all you have to do is not to attach it to black wire or any wire and cover pink end wire with electric tape.
Sep 13, 2007 | Car Audio & Video
Jensen vm9510
Attach the pink wire to the red power wire to see if unit comes on. If does then no attached correctly to emergencing brake wiring.
Apr 18, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
71 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
